Question about Hitachi 53UWX10B 53" Rear Projection Television
Hitachi Rear Projection Ultra Vision ...Need Help
The picture is very dark and despite increasing the sharpness, brightness, etc., the image remains darker than normal. Help is appreciated here!
  • 42 Answers
Symptom: DARK PICTURE OR MISSING COLOR
Cause: CLEAN SPARK GAPS, CRT PINS AND SOCKET ON CRT PWB
If you need the service manual contact me at billyjones@fletchersite.com
Posted on Mar 08, 2008
    President:
  • 1,284 Answers
The most common thing onthese Hitachi's is dusty or dirty CRT's sockets. All it takes is just for one to be dirty and it will effect the other 2 CRT's. The simple easy fix is to remove the speaker grille, then remove the access panel wich will expose the CRT boards. The CRT boards have to have a screw loose to get them to come off. Be careful as they are fragile boards and also make sure the screwdriver is not magetic and that the set is off. Just take a can of compressed air and blow out the sockets and the pins on the CRT's (again be careful as the pins are VERY fragile and will bend easy). Once this is done put the sockets back in place and you should have a normal bright picture again. If not you do have other issues but, I have fixed I would say 96% Hitachis with dark pictures this way.
Posted on Dec 23, 2007
We have a Hitachi 57XWX20B Rear Projection TV. We moved this week and now the TV picture is very dark. We have tried the magic focus and adjusted the brightness, yet the picture is still very dark. Any...
one of two things on this model==clean the lens on top of the chassis--the round large black ones.
Second: there is a resistor in the power supply that changes value and will cause this----also with set unplugged and back off since set was moved carefully look for any plugs not fully seated etc.
Apr 10, 2012 | Hitachi Director's Series 57XWX20B 57"...
PICTURE STUCK ON ONE CHANNEL, GHOST CHANNEL OVER THE TOP OF THAT AS YOU CHANGE CHANNELS...STILL SEEING THE CHANNEL THAT IS STUCK IN ONE PLACE... 55 INCH HATACHI ULTRA VISION....
This is called image burn, or image retention. There is no cure for this. The image has been burned into your picture tubes from having the same image tuned in for too long.
May 23, 2011 | Hitachi 57S715 57" Rear Projection HDTV
Dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Feb 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
PICTURE NOT AS BRIGHT AS I WANT HAVE TRIED ALL . TV IS HD REAR PROJECTION . I HAVE TRIED ALL AJUSTMENTS,COLOR,TINT,FORMAT,SHARPNESS, BRIGHTNESS ETC. LAMP ONLY ONE YEAR OLD.
Unfortunately there are 2 IC's and a capacitor that can cause this set to be really dark. Without proper troubleshooting it is impossible to diagnose. Have a shop check it out for you. Thanks
Oct 27, 2009 | Hitachi 50UX58K 50" Rear Projection...
Hitachi ultra vision green and purple double vision picture about
Convergence is out, need convergence board repaired, usually bad stks, 392-110s
Jun 07, 2009 | Hitachi 60V500 60" Rear Projection...
61 Hitachi Ultra Vision has double image
Replace both of your STKs big black ics If they are STK392-110s upgrade to 180s better ics Electronix has them call 1-800-223-3205
Dec 18, 2008 | Hitachi 61SDX01B 61" Rear Projection...
you will need to replace both convergence ICs they are STK392-110 you will also need six resistors (2) 2.2 ohm 1watt
(2) 1.5 ohm 1watt, (1) 3.3 ohm 1watt and (1) 1.8 ohm 1watt.
You can get replacemnet ICs and resistors at te following link with free instalation instructions. Here is the link.
http://servicemanuals.vstore.ca/
Jul 17, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Dark picture
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 13, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Brightness
If you want to attempt the repair the fix for most Hitachis going dark is to remove the front panel and get access to the 3 CRT's (picture tubes) Then one by one with the set off and unplugged, remove the CRT boards from the CRT's and blow out the sockets with compressed air. Once all three are done cover it all back up and reapply power and 99% of the time your picture will return to normal.
Apr 17, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Bad picture
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 26, 2006 | Hitachi 57SWX20B 57" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
118 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
