Question about Lands Phones
I need to change the auto-attendant message on our Samsung OfficeServ iDCS 28D phone system. How do I enter system administraton mode to change the message and automated directory?
  • 4 Answers
SOURCE: Problems with automated attendant on Axxess Inter-Tel Phone
When people call in they more than likely hit a Call Routing Application eventually. You would have to assign the greeting to the Day and/or Night greeting in order for it to play.
Posted on Dec 31, 2008
SOURCE: Samsung iDCS 28D Voicemail Problems
If you have administrator access use the following steps to change the code:
Access the Administratin Main Menu and select 4 for mailbox programming.
Select the mailbox to program. Dial option code 1402. The current value will be played. To hear the current value press 1, to enter a new value press 2, to hear the range of valid values press 3. Press 2 to enter new value. Enter the access code for the mailbox. The value you entered is played back. Press1 to save or 2 to re-enter. Press 3 to exit without saving. Press # to exiit or hang up.
Posted on Aug 06, 2009
SOURCE: I have a Samsung iDCS
Regarding "Same Problem": Probably said "unavailiable CBT"? In that case it's because a call button hasn't been programmed into the keyset.
Posted on May 27, 2010
consultel1
  • 860 Answers
SOURCE: I have Partner mail VS
I'm guessing that you changed the setting in the line coverage ext program (#208) or group call distrib (#206). Make sure that the settings for the lines are set to 1-assigned and not 3-VMS cover in program #206. In #208 there should be no data entered for the line if its not set up as a private line.
Posted on Jun 17, 2010
Testimonial: "Thanks, it was #206 and is now working"
PhoneSystems
  • 213 Answers
SOURCE: I have the samsung IDCS
Hi, all you need to do is to go into your voice mail via the voice mail key, once in listen to the prompts until it says ' to assign your no answer greeting'. The prompts give the option to listen and record a greeting, however make sure that you delete the original and record a new greeting other wise the messages play back-to-back! I've posted a video to help you to do this, or visit www.abbeytelecom.com for further advise
Posted on Jan 06, 2011
HOW DO I TAKE THIS PHONE OFF OF NIGHT MODE ON THE WEEKENDS
This feature is controlled by your voice mail or PBX system not by the phone. You will need to refer this issue to your telecom provider or I.T. department.
Nov 20, 2014 | Samsung iDCS 28D Digital Keyset Starting...
How do yo block a number on samsung idcs 28d?
^67 then dial the number. Test it out first by calling a phone of your own with caller ID. Also try turning off the "Show Caller ID" in the settings.
Aug 05, 2014 | Samsung Falcon iDCS 28D 28-Button Keyset...
How do I reset the time on the display ?
1. Press the transfer button and enter 200
2. Enter password ** 1234** default.
3. Enter 1 to enable
4. Press SPK button and enter 505
5. Display will read
OLD: 1040703: 1125
NEW:WMMDDYY:HHMM
For Monday April 7. time 1:00p.m
enter the following
104070313:00 and then press the Transfer button.
6. Display will return to normal..
Jun 12, 2014 | Samsung Ds-24d 24 Button Display Phone For...
Samsung IDCS 28D program VT key
Assuming you have the programming manual: get into program mode- press transfer button then 800; enter passcode (default is 4321); press volume up button to get "enable" on LCD screen; press speaker button; press 722; press extension number you want to add VT to; press button number of phone you want the VT to be on; press button to left of round scroll button; press 8 on dial pad 3 times to get to V options; press up/down arrow until VT appears; press Voice mail group number (509, 519, 529, 5049)- depends on what model system you have; press button to left of round scroll button; finally, press transfer button. you're done.
Jan 30, 2014 | Samsung Lands Phones
Flashing red light with no messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Mar 30, 2013 | Samsung Falcon iDCS 28D 28-Button Keyset...
How do you reset the password on a Samsung iDCS 28D
From the Subscriber Services Menu, Press [#] [7] [1] ....you will then hear the old password XXXXX you will be able to change it...
The Manual for a typical Samsung iDCS system is available here....
http://www.samsungidcsphonesystems.com/pdf files/idcs 16/iDCS_16_user_ins.pdf
Jul 20, 2012 | Samsung Falcon iDCS 28D 28-Button Keyset...
I have the samsung idcs 28d and I want to change the no answer greeting (if someone calls that is the message that they hear) How do I do that
Hi I am assuming that your are using the Samsung Voice Mail, if so to change the no answer greeting;
enter voicemail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voicemail message, you must press 3, delete the original message and reset the message followed by the #.
have uploaded a video off http://www.abbeytelecom.com which explains Voice-mail in more detail, if you are operating a differant system then I can only suggest that you rafer to the relevant operators manual
Mar 17, 2011 | Samsung DCS 12 Corded Phone
I need to program my Samsung system idcs 28d to add a barge key or be able to barge into calls
From any phone: press transfer button, then 800, then passcode 4321, then press up arrow on volume and set to enable mode, then press speaker button, then type 722, then type the ext number you want to change (eg. 201), then move the cursor under the 01 and type in the button number you want to add barge to, type the letter b and it will list all the features that begin with b, choose barge the press the button next to the scroll, then press the transfer key, you're done
Aug 16, 2010 | Samsung Lands Phones
How do i change my voicemail greeting on my samsung idcs 28d?
Hi, to change your Voice Mail greeting press your Voice-Mail key, enter your passcode, press 0 , 5 , 7 listen to your greeting, press 3 to delete and re-record your message. when you have done this press the # key to save. I have sent you a Voice Mail training video, i have over 65 others like it giving help and advise on the Samsung DCS.
http://www.abbeytelecom.com for written copy
Jan 29, 2010 | Samsung DCS 12 Corded Phone
Lands Phones Logo
213 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
