Question about Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
Have no pressure. engine runs fine
Engine runs perfectly. still has no pressure when you pull the trigger
4 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: 2-yr old troy-bilt pressure washer with honda
It sounds like an air lock. Try this: With the machine off, connect the hose to the washer and let it run for several minutes to get all of the air out of the hose, and to purge any air out of the pump. Shut off the water, and connect the high pressure hose, but not the gun. Let the water run for several minutes. stretch out the HP hose and make sure that the air is displaced. Shut off the water, connect the gun, and purge as before. Now crank it washer up. As quickly as safe to do so, open the trigger to keep water moving through the washer. It should come up on pressure very quickly. It is better during normal operation to keep water moving through the system. When I am through for a while, I shut down my washer, but leave the trigger depressed to allow the pump to stay full of water, and cool. This prevents further problems when I restart it.
Hope this was useful.
Regards --W/D--
Posted on Jul 17, 2009
  • 1388 Answers
SOURCE: My Generac pressure washer will work great for as
Sounds like the unloader valve built-in to your system is sticky. Try lowering the pressure of the regulator to lowest setting then re-adjusting. This will place a different pressure /load on the valve. Also when you store your unit, displace the water in the pump with oil so that lubricant will prevent the unloader from sticking. If you continue to have problem, replace the unloader. Good luck
Posted on Jul 01, 2011
  • 6468 Answers
SOURCE: Engine idles down and sometimes stalls on pressure washer when trigger on wand is pulled
clean out the carb fuel turns to **** after about 30 day for small engines
Posted on Mar 23, 2012
Pull rope on troybuilt pw wont pull out or pulls hard when trying to start it, i pulled plug and it pulls fine, put it back in and it pulls hard again if at all, can you help me out?
On some pressure washers the engine will be hard to pull start if there is pressure in the hose. Release the pressure in the hose by squeezing the wand trigger, then try starting the engine. Also If you had it running and then stopped it, you need to release the hose pressure again to have an easy time of pull starting it. This is what I have to do with mine once the pump is primed and before starting it up. I hope it's as simple as this. If not it could be an engine problem of some sort.
Hope this helps. :)
Aug 19, 2016 | Garden
Engine runs fine. But it quits when I pull the trigger on the wand to start washing
Does this behavior change if the engine is warm and on minimum choke? Do you get any water spray before the engine quits? Carburetor could be dirty or float stuck. Try putting dose of carburetor cleaner through engine and cycle choke lever and engine speed lever back and forth while engine is running after it has warmed up without running water spray. See owners manual.
Apr 03, 2015 | Craftsman 2700 PSI,2.3 GPM Briggs &...
I HAVE A RYOBI PRESSURE WASHER 3100 PSI WITH HONDA ENGINE PURCHASED FROM HOMEDEPOT USED IT 2 WEEKS AGO RAN PERFECT TRYED USING YESTERDAY AND I HAVE NO PRESSURE THE UNIT IS ONLY 10 MONTHS OLD ANY SUGGE
  • I have the exact same pressure washer..bought 10 months ago from Home Depot with the same problem..no pressure. Have you had any luck finding out what the issue is?
Jul 22, 2014 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Troy-Bilt pressure washer does not provide pressure
Sounds like your pressure pump is shot. Replace it.
Aug 29, 2017 | Briggs & Stratton Garden
I have a Honda XR2600 pressure washer. When the wand trigger is pulled, the throttle does not open, the RMD just drops. If i manually open the throttle, it works fine.
Your engine produces max horsepower at 3600 rpm. The engine throttle should be set to max before you pull trigger. Pressure washes generally do not have automatic throttle. You do not have to use max power, but enough power to keep the engine running when trigger is pulled. You washer will actually last longer if you only use about 75% of rated capacity. Good luck
Oct 15, 2011 | Karcher 2500 PSI Pressure Washer
When I release the tigger the pressure washer stops running. Runs fine as long as trigger is depressed. What could cause this?
When the trigger is pushed, the engine is supposed to rev up to increase the pressure. So from the description, is sounds like the idle speed is simply set to low and it dies. So just set the idle speed higher. You could set it as high as pulling the trigger does if you want, but that would waste gas.
Sep 04, 2010 | Briggs & Stratton Power Products 1539...
Too much pressure.
You need to keep the trigger pulled every time you start and you need to run the water for 3-5 minutes wide open before you start. Zero air should be in the line or this could cause it to **** out. You probably damaged the pump at this point.
Apr 27, 2010 | Dewalt DPH3100 Gas Pressure Washer
Gas engine will not start without pulling trigger on wand to relieve pressure-engine dies when letting off trigger
I am afraid that is how they work even electric ones wont start unless you squeeze the trigger ,once they are running you should be ablr to release the trigger , and then squeeze it again whilst running . if yours dies when you release the trgger while motor is running -----good chance you are working at too high pressure. but to start you have to release all the internal pressure
Aug 22, 2009 | Campbell Hausfeld 2000 Psi Gas Pressure...
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Jul 04, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Briggs & Stratton Pressure Washer Projectpro Spray Nozzle  Logo
167 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
