Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Have purchased the sx709 on the other uhf they can hear me but I can't hear them
  • Motorola Master
  • 1,654 Answers
Your interference code eliminator is set differently than theirs. If we were to guess theirs is set to off (zero) and yours is set to a number. Also, check to see your Qt filter, if any, is off.
http://www.motorola.com/mdirect/manuals/SX700_userguide.pdf
Posted on Oct 07, 2009
How do I factory reset a oricome 200rx uhf
Factory reset
If the radio's display locks up or stops functioning properly, you might need to reset your UHF radio. Caution: this procedure clears all the information you have stored in your UHF radio.
Before you reset your UHF radio, try turning it off and on again. If your UHF radio is still not functioning correctly you may need to reset the UHF radio! While holding the F/DPX button, turn the UHF radio on. INITI AL will be displayed for 1 to 2 seconds, the radio will then return to its original display.
Oct 02, 2014 | Radio Communications
Can not get my Motorola two way radio RMV2080 to work with a new Motorola RDU2080d two way radio
The RMV and RDU are not compatible. The RMV is a VHF radio and the RDU is a UHF radio. Contact your radio dealer where you purchased the newer RMV2080 and explain that you are UHF, they will likely do an exchange.
Best regards.
May 05, 2014 | Radio Communications
VHF/UHF RF Power falls to Zero when the Auto ATU tunr logo is on the display. When the tunr logo is off the VHF/UHF RF power is only 10 watts on 2M and 3 watts on 70cms. The Yaesu FT 857 D should have no...
Check for open or shorted Veractor diodes and steering diodes there may be no direct interaction as you say but if a diode is open or shorted the RF circuits might still be selected for the higher bands and the lower output power on your vhf/uhf is an indication of this.
If you do not have a service manual you can get one hear, you will likely kneed one
http://www.tradebit.com/filedetail.php/127575994-vertex-yaesu-ft-857-ft-857d-2005-service-repair
Good Luck Best regarsds Falco
Nov 04, 2013 | Yaesu FT-857D transceiver
I've purchased a Digitech 2 Channel UHF Microphone No:007968 from Leading Edge in Whanganui which has now closed up shop. I want to know if the system should have included a wireless unit either head piece...
This model does not have the facility for extra microphones. However, for $99.00 USD you can purchase a two mic lavalier system. It might be easier, cheaper and less frustrating. Keep in mind, I am not an employee or in any way associated with the store that I am sending you a link to.
http://www.musiciansfriend.com/search?typeAheadSuggestion=true&typeAheadRedirect=true&sB=r&Ntt=+2+Channel+UHF+Microphone+
Jul 30, 2017 | Music
HOW CAN i RESET SAT CODE FOR DIH REMOTE CONTROL FOR DIFFERENT DISH BOX
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
http://www.dishnetwork.com/SupportSection/remote-setup
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
Cannot get uhf stations
I am going to assume you have a Yagi antenna since you did not specify. There is a connection at the top of the antenna that sends the UHF and VHF down the wiring. This could be damaged. You also may need to repoint the antenna. www.antennaweb.org can assist with that matter. If you have another tv connected to the same antenna and it receives UHF then you may have a defective internal component on that particular set. Depending on your location an age of the set it may be cost prohibitive compared to purchasing a new set.
Hope that helps.
Sep 11, 2008 | Televison & Video
DTA800 do not receive UHF
I am not from that part of the country, so I can't say for sure, but check the following:
1) Are the UHF channels local and small stations? If so and under a certain power level, they are not required to broadcast in digital. THere may not be digital UHF channels local to you.
2) The changeover is required by law to occur by Feb 2009. Not all stations have made the change yet. You could still be in an area where the stations have not yet converted to digital broadcasts.
Make a few calls to find out which category yuo fall under above. If you don't fall into either of the above, update this and we'll look elsewhere for the problem.
Dan
Jun 16, 2008 | RCA Audio Players & Recorders
No uhf with antannae
UHF channels are basically "line of sight" type signals. You need to be pretty near those UHF stations.
You need a Uhf or combination Uhf/ Vhf antenna to receive them - - Usually an out-door type.
Your TV needs to be set in the "antenna" mode to tune beyond channel 13 "air type" channels. Channel 14 is the first UHF channel if you're in the antenna mode. If you're in the "Cable" mode then channel 14 is a cable channel which is operating at a different frequency from UHF.
I hope this will help you!
Stargazer
Mar 21, 2008 | Orion STV2763 27" TV
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
218 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
