Question about Texas Instruments TI-15 Explorer Calculator
When doing a simple math problem it anwers all zeros. I pressed on something earlier and I don't know how to fix it. Can you help me? I did turn it off and turned it back on and that did not work.
    Problem Solver:
  • 11 Answers
Look on the back cover and find the reset button, use a pen and press it and see if it clear the problem also check the batteries they might be dead check the back cover and see what type you need take it to the watch repair dept and buy some batteries and have them remove the back cover of the calculator and replace them. put the cover back on . your calculator will work as good as new again.
Posted on Oct 12, 2009
How do i stop stressing over my maths homework?
I know you don't feel this way, but you can do it. It may take a bit of work and finding someone/something to teach you so that you understand it the way that you learn.
First, you need your sleep. Lack of sleep will not help in your homework or other activities, in or outside of school.
How about posting some of the questions and we will see what we can do.
Keep your chin up. Once you develop some confidence in your own abilities, the sky will be the limit.
Give it a shot.
Good luck,
Paul
Jan 04, 2017 | Homework
Ti-36x Solar Scientific Calculator issue: number buttons resetting to zero...
Look in the back of the calculator, some TI models have a pin hole to hard reset the calculator.
Mar 22, 2015 | Texas Instruments - Ti-36x Solar...
Okay one day my compaq Presario F700 kept showing a message saying it needed to be restarted because something wasnt starting up when the computer turned on. So I restarted it and when it came back on the...
you disabled keyboard in fn mode press fn blue key and hold down and locate the little blue key on keyboard and press it release at same time if that dont work restore to earlier point using on screen keyboard and problem should be fixed
Mar 01, 2013 | Computers & Internet
Npr key on ti84
There is no nPr key per se. There is a menu item. Press the MATH key. You will see 4 menus; MATH, NUM, CPX, and PRB. Use right arrow to highlight PRB (probabilities). nPr is the second item in the PRB menu.
The way to use it is as follows:
In main calculator screen Type the n (10)
Press MATH>>> PRB
2: nPr
Type in r (5)
Press ENTER
So 10P5=30240
Apr 15, 2012 | Texas Instruments Office Equipment &...
How to turn on math IO mode on a sharp EL-506W calculator?
For the WriteView calculators EL-W5xx, you press 2ndF MATH to open (SetUp). Select 2:Editor, then 0:view.
Mar 22, 2012 | Sharp Office Equipment & Supplies
I have the royal ex3 digital scale and when i turn it on it just shows - - - - how do i fix it ?
I am having the same problem with my Royal ex3....changed the battery, but when I turn it on, all I get is - - - -
Anyone know what this means or how to fix it??
Jun 30, 2011 | Royal 17014c 10 lb Digital Postal Scale
I don't know my phone code
Try this steps , hope it will help you:
Unlocking:
If you have Rev 1.5 (x426) or earlier and most older models
Use the *#9998*3323# Trick (look for it on the forum)
The *#1111*WHATEVER# code will NOT work
If you have Rev 1.6 (x426) or later and most newer models
You MUST use unlocking software. Codes WILL lock your phone FOREVER
Locked: Return for Servicing
There is only 1 working solution, you must flash a copy of the firmware that is not in the locked status. (Most) Unlocking programs will NOT disable this issue, and your service provider cannot give you a code
If you do not plan to use your phone with another service provider, there is no real point to unlocking your phone other than to sell it. If you don't need to unlock it, don't take the risk of disabling the phone altogether
The *#9998*3323# Method:
1. If you have changed your phone password, change your password back to the default 8 zeros (00000000).
2. Put a SIM card that is from a network other than the one your phone is locked to
3. When Incorrect SIM error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey.
5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000)
10. Completed. You have now unlocked your phone.
Thank you for using fixya..
Please rate me on fixya and provide testimonial if ever to continue my further assistance..
May 30, 2011 | Samsung GTC3300 Cell Phone
Okay, so I'm trying to fix my exponents over here. I needed to find out what 0.77 is to the 22nd Power...so i put it in my calculator and get this CRAZY number: 3.18270183 x 10^03...What the hell???? How...
Your calculator is giving you the correct answer, telling you that 0.77 to the 22nd is about 3.1827 times ten to the minus 3, or 0.0031827 . By default, the calculator will switch to scientific notation if the magnitude of the number is less than 10 to the minus 2, or 0.01. You can put the switch at 10 to the minus 9 by repeatedly pressing the MODE key until you reach the screen showing "Fix Sci Norm" on the top line. Press 3 to select Norm, then press 2 to select Norm2.
The calculator can only show ten digits. The only way it can show a number with ten or more leading zeroes is to switch to scientific notation.
Dec 06, 2010 | Casio FX-300MS Calculator
Mp3 apacer au822
I don't really know. I can only suggest pressing the reset button (with the end of a paper clip or something similar). Sorry can't be more helpful.
Aug 21, 2008 | Audio Players & Recorders
Texas Instruments TI-15 Explorer Calculator Logo
51 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
