Question about Packard Bell DR724 Motherboard
I need conect HDD 80Gb
I need BIOS to connect HDD 80Gb
  • Fixer May 11, 2010
    it is not actually a clear question . we need some more details...is not the hdd working after connecting or you are looking for a bios update , thinking that, current wont support the hdd?
  • 272 Answers
Bios has almost nothing to do withthe HDD. You can connect it without any problem.
Posted on Oct 09, 2009
Hi, i connected an sata hdd wd5000aaks, but when i try to ninstall te windows he can see only 131072MB free. I have 5 partitions : the first is 50gb the others +- 100GB maked and formated as external...
The boards BIOS should not reference the partitions at all as this is done by software (ie OS) not the bios other than to identify the drive find its active partition and run the bootstrap.
It may be that your bios needs a newer firmware to recognize the drive correctly, or you could try manually entering the Cylinders, Heads & Sectors like the good old days, but IMO a bios update would be the thing to do.
Jul 25, 2011 | ASUS P4P800SE Motherboard
I tried to change a bad? 40GB hdd with an 80GB one, all on an Acer Aspire 1680 PC. I put Windows XP Prof SP2, on the 80GBs hdd, and after a few days work , at boot time, I saw the next error...
Check to see if the BIOS can see the HDD. If it can, check to see if the hdd is damaged(80GB is an old hdd so it could have been mishandled).
To Enter the BIOS, you can press the F2 key when the computer boots up.
To check the HDD, use the diagnostic tools on UBCD.
UBCD is free and it will require a blank CD. Follow the intructions on the download page if you do not know how to burn an ISO. Also, you may need to press a certain key to boot from CDs or make sure the BIOS boot order is set correctly.
Good luck.
Mar 25, 2011 | Computers & Internet
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
60 gb hdd does nor allow repartition
If you are reinstalling your system, it is possible that you need to change something in the BIOS settings. If your HDD is SATA, it is very likely that you need to go to BIOS setup, HDD setup, and change it. There are several options of how it may look, so whatever it is, just switch it to an other option (there are only two options every time). Try then
Nov 14, 2009 | Axiom Audio Axiom 80GB for Dell Inspiron...
I HAVE LAPTOP IBM THINKPAD T30 AND I WANT TO CONNECT HARD DISK 80GB OR MORE
  • Supported HDD thickness:
    • 12.5 mm for systems without the touch pad
    • 9.5mm for systems with the touch pad
  • Standard 20GB, 40GB, 60GB HDD sizes.
    Note:
    • The 60GB HDD orderable as marketing option part number 08K9688 has a height of 12.5mm and will not fit in the HDD slot of the systems with the touch pad installed. For these systems, it is only supported via the ThinkPad 2nd HDD Adapter for the Ultrabay 2000.
    • The 60GB HDD orderable as replacement service part number 08K9833 is 9.5mm.
  • Supports one additional HDD which can be used concurrently to offer expanded storage utilizing the Ultrabay 2000
  • S.M.A.R.T technology to issue an alert if a hardware failure is pending
  • ATA Bus Interface
  • 4200 or 5400 rpm
  • Although you can upgrade the HDD, it is not designed to be removed and reinserted on a regular basis. Repeated and frequent removal, for purposes other than to upgrade for greater capacity, can cause damage to the system. The Ultrabay 2000 HDD adapter is designed to provide this flexibility with a second HDD in the Ultrabay 2000 IBM says. I say if the OS recognises it and so does the BIOS, you're good. good luck, hope this helps.-jmattes p.s. I found this info on: http://www-307.ibm.com/pc/support/site.wss/MIGR-42218.html
Oct 17, 2009 | IBM ThinkPad T30 2366 Notebook
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Hard disk drive not detected
firstly check your cable connections, then log onto your bios setup menu during startup and check whether the Hard drive is detected by your bios, if it is then you can try to format the harddrive using the ntfs system (use the long formatt) if you are using windows xp or later if using any earlier os then formatt with the FAT32 system.
If your HDD is not detected by the bios then try to download bios updates for your motherboard and install thed in windows. is this does not work then its time to get a new HDD. thanks
May 27, 2008 | Hitachi hts548080m9at00 80 GB Hard Drive
Packard Bell DR724 Motherboard Logo
63 people viewed this question
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tony
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
