Question about Gateway FPD1975W 19" LCD Monitor
Monitor keeps turning off
I have a Gateway monitor, purchased from Circuit City. TFT LCD...FPD1975W. It will turn on, about half dark, flicker, flash a blue box about 1 inch x 2 inches with what looks like a plug with VGA in the center. Then it turns off. While it is on I can access internet, etc. It only stays on about 30 seconds to 2 minutes. Also, the icons and boxes for internet explorer all all about 4 times bigger than they were. Help!! I am on a 2nd computer in the same room.
Wally Brakefield
  • 1,684 Answers
Hello Wally,
The monitor has a power supply board that is about to die. We have a repair guide for this unit posted on our web site at: www.ccl-la.com Check it out and take the back cover off of your monitor, look at your power board and I would bet you have the same issue. There will be parts called capacitors that have the tops bulging. This is caused by heat buildup in the monitor case. If you replace the capacitors you should be back as good as new. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. Let us know if you have any questions about the repair or the repair service.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Dec 07, 2009
  • Gateway Master
  • 32,281 Answers
If the monitor is still uder warranty then return it for repair.
If you try to fix it you will void your warranty.
Posted on Oct 07, 2009
Where is the microphone
That model does not have a built in microphone, you will need to get an external mic and connect it to your computer.
May 08, 2012 | Gateway FPD1975W 19" LCD Monitor
FPD1975W TFT LCD monitor my monitor blinks a blue power light and flsahis a white screen but it does not turn on ?
A flashing power light indicates a failure of the power supply, this will also cause the white screen. Here is a link to a page showing what parts need to be replaced to repair the power supply board and get your monitor back running again.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution,
BuddyMc
Oct 09, 2011 | Gateway FPD1975W 19" LCD Monitor
I have a Gateway monitor...model FPD1975W TFT LCD HD ready...that won't show the picture...even during post. I tried both VGA and HDMI inputs...the power button turns blue...and when I toggle the input...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed GATEWAY and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 04, 2010 | Gateway FPD1975W 19" LCD Monitor
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
My gateway fpd1975w tft lcd monitor does not work. the power button just flashes blue and nothing comes on. i put an old monitor to my computer and it worked fine, and i hooked my monitor up to an old...
Restart the PC and get into SAFE MODE. Hit and release F8 many times right after turning on PC. If it works, then go into your video setting and either change the settings or remove the video driver. Restart the PC and you'll get 800X600 screen, then reinstall the video drivers. IF it won't go above 800X600, screen internals are bad, LCD toasted. I've seen that happen with LCDs and older monitors.
Jul 05, 2009 | Gateway FPD1975W 19" LCD Monitor
Glare is too much for my eyes, need a glare guard.
You can purchase a glare guard from 3m, available from cdw, tigerdirect, dell, 3m etc.
The price ranges from around $53 to $90 but you might find cheaper.
This is one model but there are several
3M™ EF200LB Anti-Glare/Radiation Computer Filter, Black Frame
May 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD2185W TFT LCD MONITOR
The backlight or inverter is going out on your screen.
Eventually it will just stay dark. You will need to replace one of the two if plan on keeping monitor.
If you find this helpful please rate so.
Thanks
May 04, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
GatewayFPD1960 TFT LCD 19 inch
cheak wheather cable is connected properly
Jan 08, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
1,046 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
