Question about Sony Cyber-Shot DSC-S40 Digital Camera
When i turn the power on the camera says "Access"
Then the camera lens keeps going in and out then it says turn the power off and then back on but it still will not work. help!! :)
    President:
  • 2,761 Answers
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Oct 13, 2009
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
Sony dsc w50 quit working
I think the memory card is full , try first taking off the battery and putting it back.
If the camera still does not work, try a different memory card.
If you still have problems, try going to setting menu and reset camera settings.
Sep 22, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Polaroid digital camera i531 was dropped. Now, lens will not go back in -- the camera comes on for a second, beeps 3 times, then turns itself off.
If your camera lens is tilt then try this,power off the camera keep lens at tilt position, on power and give a **** to opposite direction.May be it will work
Mar 17, 2010 | Polaroid i532 Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Sony cybershot 4.1 megapixels mpegmovie vx dsc-s90
Yeah, try to tapp the lens assembly with finger when it keeps going in and out.
May 05, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
The lens keep going in and out
mine camera did the same thing. i gave it to my techno neighbor guy and hours later he gave me my camera back and it was FULLY functional! he "hit it several times" thus jarring the lens back into place! (i could have gone w/o hearing that but, hey! it works!
Jan 01, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
My Sony DSC-w55 turns on and reads on ACCESS on black screen.
I had the same "access" problem as everyone else - but here's the real way to permanently fix this problem when banging and smacking it barely works.
1 - Remove battery and memory stick. Back up the mem stick if necessary or paranoid.
2 - Using a small Phillips head screwdriver, remove all of the screws you see from the front (lens side), right and left sides of the camera. Then remove all three of the covers and place aside.
3 - Clean and remove all dirt & dust in and around front of camera, paying special attention to areas close the lens and lens housing areas.
4 - Insert battery and close the battery cover and then PLACE THE CAMERA RIGHT-SIDE UP ON A FLAT, NON-METALLIC SURFACE, MAKING SURE THAT YOU'RE NOT TOUCHING ANY OF THE EXPOSED CIRCUITS OR WIRING TO AVOID POTENTIAL SHOCK. This isn't a danger issue, more of a cover-my-*** related note. When I did this for my DSC-W55 I touched it just about everywhere without receiving generating anything close to a shock.
5 - Press the power button. If lens does open fully and you're still receiving the "access" message, continue powering off and on while using a toothpick or compressed air to remove remaining dirt and dust particles.
6 - When you're DSC-W55 is back in business - and after you've tested it multiple times via several on/off cycles, begin replacing the covers one at a time. The trick is to replace one cover, then to test the camera again via several on/off cycles. Do this until you've reattached all covers and camera is fully operational once again.
Tip - you may find success early by varying the tightness of the screws for each side's cover as you move along the on/off cycle process.
Dec 22, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Access error
Describe what you are doing when this occurs.
Taking pictures or uploading for example
Nov 17, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Lens coming out and going back in when turned on
Lightly hit your camera in you palm a few times. I has the same problem with my DSC-W55 and it works now!
Oct 12, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Getting access
Was your unit dropped, or maybe left with the lens protruding? Seems you have a problem with the lens assy(stucked), during start-up, it will initialize to check if all systems go, if not then it will display turn off and on again. thanks
Sep 06, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
52 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
