Question about Vehicle Parts & Accessories
My engine will not switch off? 2006 seat leon new model 105 tdi referance.. the engine keeps running when i turn it off.. any help would be great.
    Genius:
  • 1,341 Answers
For how long does it run when you power off the ignition? Some models needs to run for a few minutes even though you have switched off the ignition.
Posted on Oct 06, 2009
On a 3.8L what is the aspec diagram and tourque for the racker arm
Hi Juan, I'm AL the owner of Big As Auto Repair
Below is the torque specs for the rocker arm as you requested.
SPECIFICATIONS - TORQUE
DESCRIPTION N·m Ft. Lbs. In. Lbs. Camshaft Sprocket-Bolt 54 40 - Camshaft Thrust Plate-Bolts 12 - 105 Forged Connecting Rod Cap-Nuts 54 +¼ turn 40 +¼ turn - Cracked Connecting Rod Cap-Bolts (Refer to 9 - ENGINE/ENGINE BLOCK/PISTON & CONNECTING ROD - INSTALLATION) Crankshaft Main Bearing Cap-Bolts 41 +¼ turn 30 +¼ turn - Crankshaft Main Bearing Cap Cross Bolts (3.8L) 61 45 - Crankshaft Oil Seal Retainer Rear-Bolts 12 - 105 Crankshaft Damper-Bolt 54 40 - Cylinder Block Drain Plugs 20 15 - Cylinder Head-Bolts (Refer to 9 - ENGINE/CYLINDER HEAD - INSTALLATION) Cylinder Head Cover-Bolts 12 - 105 Flex Plate to Crankshaft 88 65 - Engine Mounting (Refer to 9 - ENGINE/ENGINE MOUNTING) Powertrain Torque Strut 54 40 - Exhaust Manifold-Bolts 23 - 200 Exhaust Crossover Pipe-Bolts 54 40 - Intake Manifold - Lower-Bolts 23 - 200 Intake Manifold - Lower Gasket Retainer-Bolts 12 - 105 Intake Manifold Upper-Bolts 12 - 105 Lifter Yoke Retainer-Bolts 12 - 105 Oil Filter Attaching Fitting 54 40 - Oil Cooler Attaching Fitting 27 20 - Oil Filter 20 15 - Oil Filter Adapter-Bolts 28 - 250 Oil Gallery Plug 27 20 - Oil Pan-Bolts 12 - 105 Oil Pan Drain-Plug 27 20 - Oil Pressure Switch 23 - 200 Oil Pump Cover Plate-Screws 12 - 105 Oil Pump Pick-up Tube-Bolt 28 - 250 Oil Dipstick Housing-Bolts 48 35 - Rocker Arm Shaft-Bolts 23 - 200 Spark Plug 16 12 - Thermostat Housing 12 - 105 Timing Chain Case Cover -M8 Bolt 27 20 - -M10 Bolt 54 40 - Water Pump-Bolts 12 - 105 Water Pump Pulley-Bolts 28 - 250
Should you need extra help visit my website here: http://www.bigasautorepair.com/
Apr 15, 2015 | 2005 Chrysler Pacifica
2002 seat leon, engine died while driving ? :o(
Do a compression test. Your engine may need an overhaul.
Jul 20, 2014 | 2000 Seat Leon
Seat leon engine
disconnect negative battery cable for about 15 min & reconnect
Apr 21, 2014 | 2000 Seat Leon
When driving my seat leon 2.0 ltr tdi after approx 2 miles the abs and tcs lights come on
what are the dtc codes at your abd control modules at adress 03? it might be pin outs corrosion at abs sensors, wirring harness , but before you have to check dtc codes using diagnostic tool
Apr 01, 2014 | Toys
Where is the fuel filter location on a seat leon s 1.4 litre petrol
The light is not due to any clogged filter issue, you have an engine fault in one of the sensors most likely.
Mar 21, 2014 | 2000 Seat Leon
Snapper nearly dies when brake is released
sounds like one of the safety switches are going bad there is one on the deck it looks like a finger
Jul 12, 2013 | Snapper 7800785 - 2812524BVE 28" 12.5HP...
Seat Leon Fan Control
We do not have this make in the USA so have no info on it.
Jun 07, 2012 | 2006 Seat Leon 2.0
I have a 2006 seat leon 1.9tdi speed limited? please help
yes it is a saftey thing in event of having a crash you need to get them sorted otherwise it will fail on its next MOT
Feb 27, 2010 | 2001 Volkswagen Golf
How do I fill the gearbox oil on my Seat Leon 1.9 TDi? (same engine as a VW Golf 1.9 TDi)
If the car is a manual shift,the filler / level plug (Allen key) is on the front of the gearbox. Simply remove and fill to this level. Box holds 2.5 litres of 75/ 80 grade oil. Do NOT use EP grade
All the best
John
Aug 27, 2009 | 2005 Volkswagen Golf
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
