Question about Bosch Classixx KSR32623 Refrigerator
How to reverse the doors on bosch classixx fridge freezer and reverse the handle it does not look like you can change the handles
  • 14 Answers
SOURCE: Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Posted on Jan 17, 2008
aborcass
  • 2651 Answers
SOURCE: Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Posted on Mar 12, 2008
SOURCE: Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Posted on Nov 15, 2008
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
How to tighten a loose door handle for On the fridge upper half?
Gain access to inside of refrigerator door to refasten the loose handle.
Mar 06, 2016 | Bosch B36IT71SNS (20 cu ft) Bottom Freezer...
Hi, got a fridge freezer, the freezer door is not closing -please help
check if noting broke in the door locking mechanic. Or check if not too much ice is pressing the door open.
But if you don't hear the click, check the lock.
Feb 26, 2015 | Bosch Kge Series Fridge Freezer Door...
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
I have a Bosch Classixx KGV28V01GB fridge freezer. I defrosted it as there was a bog built up of ice in the freezer. I switched the fridge freezer back on today and have noticed that the fridge is not...
it will take at least 48 hours for a large fridge freezer to settle down after a complete defrost,so leave it alone with the door shut,set at you favourite temp....
Jul 27, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Jul 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
We have a Bosch Fridge Freezer Model No KGV3120GB/03 we wish to reverser hang the doors but can't undo the top post in the fridge and bottom one in the freezer don't want to apply too much pressure in case...
We have just reversed the doors on our Bosch Fridge Freezer. The posts were very difficult to unscrew but was eventually possible using 2 mole grips. It is definitely a screw fitting. Good Luck.
Jan 02, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch Fridge Freezer Freedom Classixx
Hi there seems that the power supply unit has a fault and will need replacing suggestion to call an engineer.
Thanks J
Jan 01, 2008 | Freezers
Hope this helps
Deep diver
Dec 22, 2007 | Refrigerators
Bosch Classixx KSR32623 Refrigerator Logo
1,707 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
