Question about Mitsubishi WD-62525 62" Rear Projection HDTV
There are flickering, rainbow-like color bands running across the screen, especially in the component inputs, not so much using the HDMI input, but still there.
  • 336 Answers
Hi,if your tv is and Lcd rear projection it will be the light engine that needs replacement.Because lcd technology uses 3 chips green,red and blue that create the image and colors.When they start to fail you will get what you are getting color discoloration and rainbows.If your tv is DLp it will be the dmd chips which basically its like the lcd chips but instead of 3 chips its only one that creates the image.Hope this works God bless you!
Posted on Oct 06, 2009
Hitachi le55a6r9a sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board . In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
http://electro-medical.blogspot.com/
Jan 23, 2017 | Hitachi Televison & Video
I need help identifying if I have some banding issues on my TV. I notice with dark colors, they tend to bleed out horizontally across the screen. Do I need to replace a board?
First thing to check is if the problem happens in all inputs or just one or two. If it happens on all the inputs then it is a t-con board.
May 13, 2016 | Panasonic Tc-p42c2 Viera C2 Series 42"...
What would cause the colors on my 32" Dynex TV flicker, losing an RGB range as if someone had pulled out a component cord from an input (I have tried this with HDMI and VGA, I am NOT using the compone
Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 27, 2015 | Dynex Televison & Video
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Have connected dvd/vcr but the tv screen is blue. Can you help please.
You MUST select EXTERNAL Input, NOT a Channel. You MUST connect up via, the INPUTS at rear, either COMPONENT, or COMPOSITE, Or, HDMI. Except for HDMI, ALL Cables, go Color Jack, to Color jack. 3 for composite & Audio, and 5 for Component & Audio.
Apr 23, 2010 | Sanyo DVW-7200 DVD/VCR
How can I attach an HDMI BluRay player to my TV
Blu-ray attaches to component inputs. Component cables are the red-green-blue cable and the red and white for sound.
Out on the blu-ray to 'In' on the TV.
Here is your owner's manual. see page 19
Feb 20, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com service@electron-age-technologies-llc.com
May 30, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Purple color band at top of TV screen
If the problem is visible on all inputs (DVD, sat, etc.) you have a bad optical block. That model has a two year warrnty on the block but you'll have to pay labor to get it replaced
Oct 16, 2008 | Sony KDF46E2000 46" Projection HDTV
Problem with component input and 720p HDMI output
does your cable box have an hdmi output? if it does try an hdmi cable instead of componant cables[ i know the hdmi cables aren't cheap] if not, if the reciever has componant outputs, use them instead.
hope this helps
wg
Feb 02, 2008 | Onkyo TX-SR605 Receiver
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
267 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
