Question about Telex H-551 Consumer Headset
Telex H-551 Digital USB Headset and Audio/Microphone
I plug in and no reponse or new hardware recognized
Call 1-800-898-6723 x 1 (if outsidethe USA call using SKYPE. It is free to call USA toll free numbers using SKYPE.
The driver is the same for P-500. It is about 14KB in size.
I got mine today from TELEX. It is 01:11 July 29, 2008, Indian Standard Time.
Best regards,
Randy.
Posted on Jul 28, 2008
Does not work with telex 850
Don't know if you are using the PA-97 adapter, it should work without any problems. I would check the potentiometer "gain" adjust on the microphone assembly. Hope this helps ;)
Jan 30, 2014 | Pilot USA Fixed Wing Headset to Airbus...
I did not hear any sound on my headset anymore
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
hope this helps
Sep 15, 2012 | Gateway Computers & Internet
How do I configure my Dynex USB microphone?
try uninstalling it and then re-installing it:
Plug the USB connector into an available external USB port on
your computer or laptop. On most computers, drivers install
automatically and your microphone will be ready to use.
Note: On Windows, if you are prompted with the Add New Hardware Wizard, follow the steps to download and install the driver.
Jul 07, 2012 | Dynex USB Microphone
Headphones usb not working
try uninstalling and then re-installing it.
USB port on your computer or laptop. On most
computers, drivers install automatically and your
headset will be ready to use.
Note: On windows, if you are prompted with the Add New Hardware Wizard, follow the steps to download and install the driver.
If you can not hear audio on your headset, adjust some or all of the following settings:
• Plug the USB connector into an available USB port.
• Check your computer's volume level.
• Check if your computer's volume is muted.
• Check your operating system's audio input and output settings.
• Check the headset's volume and mute settings.
• Restart computer.
Jan 22, 2012 | Dynex Mono USB Headset with...
When I plug in my Audio 625 Plantronics to my usb port it shows an error - Device not recognized, please help..
If you are using a Mac computer your Plantronics .Audio headset will not work The microphone plug on the .Audio analog headsets is not compatible with a Mac. It will physically fit into the Mic input jack on a Mac; however, it will not function. Basically, the digital sound card does not recognize the analog signal coming in from the headset.
Good luck from Headsets Direct!
Apr 16, 2011 | Plantronics Audio 625 Headset
Okay, so i've tried to plug the headset into all usb ports and no sound will work, what the ***** going on yeah.
You need to download or install the drivers for the audio. Did the headset come with a CD? IF so install by using the CD. If not go to www.logitech.com and download the appropriate drivers for your headset. Can also go into system, hardware and install/search for driver. BTW do you get a message that new hardware has been installed when you plug in the USB plug to your USB port?
Oct 15, 2010 | Logitech ClearChat Pro USB Headset
Insignia NS-BTHDP ok with phone, pairs with PC but can't connect
Make sure the headphones are set as "default" under Control Panel>Hardware and Sound>Sound>Manage Audio Devices - same for microphone if you're using it for online speech.
Jun 04, 2009 | Insignia Bluetooth Wireless Headphones...
Computer wont recognize me Saitek GH20 Headset
I have the same problem. I suspect that this headset is not USB compatible at all. It possibly only uses the USB connection as a source of power (for the vibration effect). This is a problem for me because I wanted to use the headset on a PS3. Saitek don't claim that it works with the PS3, but the claim of USB compatibility is ambiguous and misleading in my opinion.
Feb 20, 2009 | Saitek GH50 Headset
I need help!!! my headset is buzzing lol
check the audio setting. If AUX is turned on instead of Microphone, it will cut out because its waiting for an input from another source.
make sure the LINE-IN isnt turned on or the S/pdif-in.
Only have on the ( PLAYBACK, WAVE, CD AUDIO, MIDI, and Microphone. And there not muted or turned down.
If its USB it may need drivers but they should have come on a CD with it.
Also make sure that if your using sound card, that its set up in the audio properties to be the audio renderer
Mar 31, 2008 | Audio Players & Recorders
I get no sound and my my microphone doesnt work.
man this is all **** i got same problem no one knows how to fix !!!
Jul 22, 2007 | Logitech 250 Headset
Telex H-551 Consumer Headset Logo
646 people viewed this question
Top Telex Radio Communications Experts
Andrew Taylor
Andrew Taylor
richie46
Are you a Telex Radio Communication Expert? Answer questions, earn points and help others
