Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Blinking green light
Just replaced the 1000uf16v capasitor with a 1000uf25v capasitors and I had a TV repair man do this and when I reinstalled it in the tV the green light still flashes, any solutions
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Did he try to disconnect the front keyboard on this set?
ONLY 1 or 2 things can cause this problem----First thing to do is remove front speaker grill--it pulls out and secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboardBlinking green light - 2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard2.gif with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up.
If disconnecting the keyboard2.gif allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---you can call them and get a quote for repairing the receiver.
Did he try to disconnect the front keyboard of this set? it has the reset switch on it---------and the switch can cause this problem!
SD TECH
Posted on Oct 06, 2009
5551355 green light blinking capasitors are bad need to know number on capasitors
well, I fix it my ws-55517 and I changed 4 capasitor from DM Board, numbers :C81..C81a..C82b...C81c....1000ufd,16v,105c
Jun 21, 2014 | Mitsubishi WS-65869 65" Rear Projection...
I heard some sound and my monitor stopped working not even starting Model is LG L1719SLCD
The sound you heard is typical of a blown capasitor. A capasitor over time gets stressed and can bulge, it then pops when the pressure gets too much.
All that needs to be done is to solder in a new capasitor with one of the same value, then your monitor should work again.
Claim warranty support if it is available to you, another option it to contact an appliance repair man or a computer technician.
Take care!
damnor01
Aug 14, 2011 | Computers & Internet
I have a le46a lcd samsung tv . the tv will not turn on . it clicks and the the red light flashes. i see that their is history of this but i can not find any answeres. thankyou
Your issue is your power supply. You can eather replace some capasitors on the power supply or you can replace the entire unit. If you open the LCD you should be able to see blow up capasitors.
Average repair is about $225 to $275 if they need to replace the entire board.
Thank you,
Nov 21, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Found problem but need to know capasitor
Check this page on our web site at: http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/ We have repair guides for all three versions of the Dell E173 monitors. If you need any additional information just let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 27, 2010 | Dell E173FP 17" LCD Monitor
TV green light turns on. YOu could hear the audio out of the receiver which is connected to DirecTV. But, no video.
Hi, Look for bulging capasitors on the DM module board located to the left from the back of Tv and replace them. Should fix the problem or call a local Tv Repair Shop. Thanks.
Sep 22, 2009 | Mitsubishi WS-73905 73" Rear Projection...
Mitsubishi blinking green light
Hi, Replace the Lamp or the four bulging capasitors on the power supply board. Thanks.
Sep 21, 2009 | Mitsubishi WD-62525 62" Rear Projection...
TV is blank and status light is blinking yellow
I think you have a powersupply problem. This model has had alot of problems with bad electrolitic capasitors through out the entire chassi assy. Because of the way the manufacture designed this unit you may be better off getting a Mitsubishi Authorised service company to fix it. If you feel confedent,
check the powersuppy for 2 electrolitic capasitors that are bulging on the top. They will be your culpirts. I believe they will be 25v 2500uf. But don't hold me to it.
Hope this helps,
Skyassoc
Jun 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
T.V. turns on, then turns off
Check your all capasitors of pwd supply any capasitor is lickege or short or not work poperly if you cann't find any problem replace your all capasitors of pwd supply
Mar 12, 2009 | RCA 20F410T 20" TV
Model WS 73713, mitsibushi big screen TV. green blinking light on front panel doesn't stop blinking and tv will not turn on by remote or power button on panel
called a TV repairman. I know $65. to start service call but feel it will be fixed correctly in a timely manner.
Sep 08, 2008 | Televison & Video
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
287 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
