SOURCE: KENMORE MICROWAVE (HOUSEHOLD) LOCKED
It sounds like you press STOP two or three times to lock it. Maybe that (or another key) will unlock it.
The lock / unlock procedure will be covered in your owner's manual.
Or you can try a hard reset - unplug it from the wall for one minute, then plug it back in and try again.
If you don't have your manual, you can get one here. (Enter your model number without any spaces)
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Kenmore Galaxy Microwave Hood Combo Model 72180002400
Since it sounds louder than before, it is probably a bad high voltage diode or magnetron.
If
it's within the magnetron portion of the warranty (usually 5-9 years)
but out of the original full warranty (usually 1 year), then your
manufacturer will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
Sears may send you a magnetron to install yourself since it's under warranty. For that or warranty service, contact Sears at http://www.sears.com.
You can save about $75 by taking it to the shop yourself, as opposed to an in-home service call.
SOURCE: Kenmore microwave Model #"721 8924681" "L" in lower corner
It is child lock and you can unlock it by press and hold the start button.
SOURCE: display panel works but no heat, no fan, turn table doesn't turn
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If you or someone you
know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site, and our link is at our listing here on
FixYa:.
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting & testing.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases in about a week or so.
We're
SOURCE: Sharp microwave oven model r-1440 runs, but doesn't heat food
Assuming your inside light and
turntable come on when you try to microwave, with the symptoms you have,
I would most strongly suspect a bad magnetron or a loose and possibly
corroded connection on the magnetron's terminal.
If
you or someone you know decide to look into it, we have critical safety
information and disassembly information at our site, and our link is at
our listing here on FixYa.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
(if it's not shorted or burned, it'sprobably okay)
The best place to order
parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
