Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Profile stovetop spark element will not stop firing all 4 burners are sparking and will not stop unless I unplug the unit
  • GE Master
  • 3,361 Answers
You have a bad spark switch on one of your burner switches.
Remove the control panel to access the switches and burner stems. Carefully remove one wire at a time from each switch. When the sparking stops,that will be the bad switch. Replace the bad spark switch.
Posted on Oct 06, 2009
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Piezo igniter won't quit
Possible stuck burner switch or failed spark module. Unplug unit. Remove wires from burner switches at module and plug back in. If it starts sparking, replace module. If it stops, then replace switch harness.
Jan 18, 2011 | GE 30 in. Profile JGP932 Gas Cooktop
GE gas stovetop burner doesn't light
there are sparker modules on each burner behind the button, it may be that yours is failed, if you turn on other knob and you see spark at problem burner and still isn't lighting you have to make sure the black or grey tops are paced on perfectly, just give them a little nudge and you have to make sure area is perfectly clean for spark to take effect, spark will go for cleanest area on metal. so ensure area is clean and check burner top
Feb 05, 2010 | GE 30 in. Profile JGP979 Gas Cooktop
Kitchen aid sparking on all burners
one of the burner switches is shorted, take off plate that covers the switches and remove the wires one at a time on each switch then reattach wire before going on to next switch.continue until sparking stops,replace switch (easy fix)
Sep 08, 2009 | KitchenAid Kitchen Ranges
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Spark ignitors on gas stovetop wont stop sparking
Make sure yo haven't spilled liquid on the ignitor becuase this will cuase all ignitors to spark constantly. If all is dry, the spark module must be replaced.
Feb 15, 2009 | Cooktops
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Viking 4 burner gas range
if you are not hearing the faintest sound of clicking / sparking you could have a bad spark module or even bad burner switches i doubt that all switches went bad at the same time but its possible unplug oven check wireing to switches and spark module if you pull your burner knob off thats the switch starring at you follow wires and check for any loose connections
Dec 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
We have a 5-burner GE cook top/ The igition for the center burner continually fires.
the spark modual is bad in the cooktop. you can just leve it unpluged and light with a match until you can get it replaced
Nov 22, 2007 | GE 36 in. Profile JGP962 Gas Cooktop
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
258 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
