Question about Whirlpool Dryers
Recently the heating element was replaced along with a sensor. Since then it has been running fine, but about a month ago, the wire attached to the heating element corroded through. I initially thought that it was just a bad wire end, so I clipped it off and reconnected. Last week I noticed that the dryer kept running for extended period of time, and it was no longer getting hot/warm. I pulled the back cover off and the wire that previously corroded through, was again severed, the wire damaged due to heat, and the male attachment for the heating element burned through, also severed. It appears to have too much power going thru the wire to the heating element overheating the wire and the overloading the wire.
    President:
  • 1,304 Answers
More often than not those connections are loose and that jsut cannot be
but check your outlet voltage it should read 220 across the poles anything else it could eb trouble
Posted on Oct 06, 2009
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag Dryer MDE3706AYW has a burnt black wire, did the wire just have a bad day or do I need to replace the heating element and the wire?
All should be good. I think the element had run on due to a bad hi-limit thermostat that you said you replaced.
Oct 17, 2012 | Maytag MDE3706 Electric Dryer
I have a Maytag Model LDE4916ACE dryer that recently the timer stopped woking two days ago, the next load it did the same went and went now today it does not heat. Any clue?
the heating element has overloaded and shorted out - new heat element is required along with a new timer switch .
Jul 23, 2011 | Dryers
My Kenmore Elite dryer just quit heating up...is it the heating element or possibly a fuse? The lint trap had qite a bit of lint in it..maybe it just over heated and blew a fuse?
There is a thermal sensor attached to the housing of the heating element, you can check the thermal sensor by jumpering the two wires to the thermal sensor together, and then run the dryer and see if the heating element is now working, if the dryer is now heating up then replace the thermal sensor.
May 10, 2010 | Dryers
I have an similar problem with my Amana Dryer LEA30AW.
First Clean out your filter, Assuming the element is okay and cut-out are fine it should run okay, you could also try running it on low heat will take a bit longer but hey if it works great..Good luck
Oct 01, 2009 | Dryers
My dryer will not heat. I had this problem about 6 months ago. I have a res6745rq0 model.The thermostat was replaced and the fuse 6 months ago
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 16, 2009 | Dryers
Electric dryer not heating...works fine, but no heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Jun 04, 2009 | Roper RGS7646KQ Gas Dryer
1998 Chevy tahoe Hard to start when cold
replace your MAP sensor(manifold absolute pressure) the map sensor is the computer for your fuel pressure regulator telling how much pressure. Unless your tahoe runs like **** going up hill than it inevitably your fuel pump
Feb 17, 2009 | 1999 Chevrolet C/K 2500
JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
May 25, 2008 | GE JBP66 Electric Kitchen Range
Dryers Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
