Question about HP Photosmart C6100 All-In-One Printer
Just purchased an HP Photosmart Premium want to turnoff ringer
Either shut off the ringer or turn down the volume ..... could not find any info in the manual
To turn the ringer off - press Setup button and scroll down to Basic Fax Setup and press Select. Then scroll down to Fax Sound Volume and then scroll down to Off and press Select.
Posted on Dec 15, 2009
How can I turn set the fax ringer to silent on my photosmart c6180?
Press setup,press bottom arrow to[basic fax setup] press OK,Fax sound volume bottom arrow to off press OK.
Aug 08, 2013 | HP Photosmart C6180 All-In-One InkJet...
Hp Photosmart Premium C309A INK SYSTEM FAILURE Oxc19a0022
When errors like this occurs, it is advised to reset the printer first before any other step(s) is taken;
Press *(star) and # (hash) together on the printer and let go.
Key 1 then2 then3
Press the right arrow key until the on screen menu shows System Configuration
Press OK
Press right arrow key until failure status is displayed
OK again.
Keep pressing cancel till you get back to the main menu then
Unplug from power for 1 minute then plug back in
Power back on.
Or
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate.
If after resetting, the error still appears, the it means the print-head assembly or white pump gear in the printer needs to be replaced. But if your printer is still under warranty , replacement will be for free by HP.
Good luck.
Mar 15, 2011 | HP Photosmart Premium C309A All-In-One...
HP Photosmart PremiumC 309g-m started a day ago will not print anything even test page. Message says load paper into photo tray. Nothing obvious seems to work, shutting down printer and restarting,...
Unplug the power from the printer.
Press the # key and the 6 at the same time and hold them down
connect the power while continuing to hold down these keys
wait for a message about a semi-nvm reset or something like that to appear on the screen, and then release the buttons. If the unit shuts down while you are pressing the buttons, release them, and press power just long enough to turn the unit on.
If the printer does not react normally after this, post a reply here.
Feb 24, 2011 | HP Photosmart Premium C309A All-In-One...
My c309 photosmart is stuck in shut down mode just says "shutting down" can't turn off
brose,
Do a power cycle on your printer and it should hopefully fix your problem. To power cycle, follow these steps:
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then reconnect the power cord to the product.
  4. Turn the product on.
Take care and good luck!
Feb 16, 2010 | HP Photosmart Premium C309A All-In-One...
HP Photosmart Premium when I try to scan it says
Try this: first shut it off, second disconnect USB cable third unplug power cord from back of printer, fourth unplug power cord from wall (or power strip), wait 15 minutes. Then reconnect everything in reverse order and see if that solves it.
Jan 16, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
How do I shut off the ringer on HP Photosmart Premier C309
Press the Setup button, go to Basic Fax Setup, scroll down to Fax Sound Volume, select Soft, Loud or Off. On ours, "Soft" is way too loud.
Dec 01, 2009 | HP Photosmart Premium C309A All-In-One...
How do you shut off the ringer on an HP C309?
Oct 30, 2009 | HP Photosmart Premium C309A All-In-One...
Ringer not working
On the base press the volume up [^] key. Repeat pressing to get higher volume. Press volume down [V] for reducing the volume. Press and hold volume down for two seconds to turn ringer off. On the handset, you can use the menu to turn ringer on and off.
Nov 19, 2008 | Panasonic KX-TG2313 Cordless Phone
How do I turn down the ringer volume on my HP 6210 Officejet
follow the ff. steps:
  1. press set-up
  2. press 4 and then press 6 (this selects BASIC FAX SET-UP and then RING,BEEP and VOLUME)
  3. press right arrow key to select one of the options:SOFT,LOUD and OFF (NOTE: if you are going to select OFF no will not hear dial tone,fax tone and incoming ring tones)
  4. press OK....
try this steps and give me feedback....*mrbench87*
Aug 25, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Photosmart 2610
hmm..you may need to remove that premium plus option, through the system preferences folder. Then re install the drivers(get em here for updates) for the Inkjet printer. And be sure to only select the features you really want.
Mar 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart C6100 All-In-One Printer Logo
645 people viewed this question
Ben Johnson
