Question about Lexmark Z645 InkJet Photo Printer
I have ink and it is acting as if it is printing, but nothing is on the paper
    President:
  • 1,335 Answers
If you are not getting other error messages, the chances are that you have clogged nozzles. If you are using aftermarket or refilled cartridges, they are most likely the culprit. To clear the problem, insert new OEM cartridges, run the nozzle cleaning utility, align the printheads by using the align utility and the problem should clear.
Let me know if this solves your problem. If it does not, we can test some other things. Thanks.
Posted on Oct 06, 2009
Inky
  • 691 Answers
SOURCE: Acts like it is printing but nothing comes on the paper
Try the following the intensive cleaning info in this rescue kit to regain print quality. There is also a known issue with some CX machines where a pipe gets blocked and the ink in the head can't flow. This is covered in this other rescue kit info.
Posted on Feb 17, 2008
SOURCE: after replacing the black ink nothing prints
Hello, I am having the same problem and have done extensive research to find out that with this exact problem you have mentioned, you must clean the printer head, nozzles, and waste ink tube. the process is a bit long and needs patience. You will have to take the print head assembly out of the sliding caddle and put it in a glass of rubbing alcohol to disolve the dryed ink within the printer head assembly. it is held in with a silver metal plate that runs across the assembly and screws to the sliding carriage. be carefull to remove the black clip on the right of the carriage to take it out. note to be careful to not pull the white info lines of the head. leave it in the glass overnight and also clean the tube that runs under the waste pad station and clean the clear waste tube as well. ....Good luck
Posted on Apr 08, 2008
  • 9 Answers
SOURCE: Not printing
its a problem with cartiges circuit change cartidges
Posted on May 20, 2009
aicaxz
  • 511 Answers
SOURCE: Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
Posted on Jun 01, 2009
pineworks
  • 4041 Answers
SOURCE: Paper feed through printer but comes out blank
Hi
Yes if it been standing a long time it can dried out,
Some times it needs a good clean up but this is up to you if you want to do this I put down here. But after you don this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 14, 2010
My printer is acting like it's printing nothing
Yes it is a ink problem so try and replace the ink.
Jul 02, 2010 | Lexmark X5470 All-In-One InkJet Printer
Ink cartridges are all full, but when I print, it acts as if it's printing but nothing appears on the paper.
  1. Turn off the Stylus CX.
  2. Load letter-size paper in the sheet feeder.
  3. Press the cp_button_48_er.gif ink and cp_button_1.gif On buttons together and hold them down for about 3 seconds.
    The Stylus CX turns on and prints a test pattern, which includes a nozzle check. Shown below are some examples of what the nozzle check may look like.
Nozzle check pattern with no gaps im_158_er.gif Nozzle check pattern with gaps im_159_er.gif
Feb 15, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Brother 665cw wont print has new ink acts like it is printing but nothing on paper
There is always a protective film on the print nozzles of the cartridge. Have you removed it? DO so now and print again. If you have and the prob still persists, then clean the contacts on the cartridge and the printer. Prob still persists, then go to printer settings and in trouble shootin option, clean the print nozzles. It will print an ink intensive page and the nozzles will be cleaned.
Aug 17, 2009 | Office Equipment & Supplies
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Have you removed the tear off tape from top of cartridges, it lets the air in and ink flows.
May 28, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Will only print in blue ink
most likely you are out of ink other than blue, try to refill the other colors or get new cartridges.
Mar 26, 2009 | Canon Office Equipment & Supplies
I press print. It acts all busy and loud. Prints NOTHING
If paper is feeding through and you don't get any errors try this: Try doing 4 to 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Lexmark z23 will not print
go to the printer properties---there select printing preferences ---there select lexmaxr solution center-----in that option select printer cartridge replacement option----in that follow the replacement instructions.and select the cartridges.as it is new.and its proper appropriate number.then only it will print properly. selecting the cartridge is very much necessary.
Sep 12, 2008 | Lexmark Color JetPrinter Z23 InkJet
some cartridges comes with deffects, replace with new one or reclaim warranty to your dealer
Mar 08, 2008 | HP PSC 1410 All-In-One InkJet Printer
Oct 21, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Lexmark Z645 InkJet Photo Printer Logo
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
