Question about Recoton Advent Advent Q2035A 20" TV
Advent laptop 7105pa
Wont boot up gets to cmos settings and says cmos settings wrong mos date/time not set press f1 to run setup f2 to load default values and continue . tried both to no avail
2 Suggested Answers
SOURCE: advent 4211c web cam set up
have you tried the Fn + F6 key combo? you can then use the cyberlink youcam software that is on the programs menu - i think you might have to register the software whne you first set it up.
Posted on Jan 26, 2009
  • 70 Answers
SOURCE: Infomation for fitting cmos battery to Advent 7094 laptop.
here you may get the answer.
Posted on Jan 14, 2010
0 characters
1 Points
Advent @ key how does it work
If when you key CTRL + @ keys you get a number 2 then your laptop language is set to "English USA" simply reset language to "English,English"
Dec 25, 2012 | Recoton Advent Advent Q2035A 20" TV
I have a one year old Broksonic 19" flat screen LCD TV. I wanted to use it as a computer monitor, so I hooked up the VGA cord and selected PC as the input. Nothing. What am I doing wrong? Charles...
Is the computer set to send data to the video port? Laptops often have the external port disabled; check the BIOS. (This is often accessed by pressing F1, Esc or F2 before the OS loads. Check your documentation.) Then you can set the preferred monitor by looking at the Display settings.
Some desktops have a similar issue where only one port is active (DVI, HDMI, and VGA). You may need to connect a different monitor via the enabled port or use an adapter to get the VGA cable to mate with that port to change settings. (In the case of computers with video graphics cards and motherboard video ports, only one item is active. Try moving your cable with an adapter if needed to one of the other ports. Then change the BIOS setting if you do not want to continue using the adapter.)
Try a different video cable and make sure it is fully connected to both the computer and the monitor. Damaged cables are always suspect.
What OS are you using? Do you need to download drivers for the Broksonic? Go to and ask in the Product support section - they don't seem to have a direct link on the site. (For example some TVs are not compatible with the drivers in the Mac OS.)
I hope this helps.
Aug 21, 2010 | Broksonic TV
Turning on the bluetooth setting on the advent 4211c
Hi, after searching for hours on the internet, then a little longer on my notepad I realised you use the function key for additional features - so for bluetooth hold down (Fn) in the left corner of the notepad then press (F11) at the same time, your bluetooth should switch on, then select the minimized icon to apply your settings!
Also if you're having trouble with your camera hold down (Fn) and (F6) at the same time, then camera should switch on!
Simple, If only they made clearer!!
Hope I've helped
Jan 27, 2009 | Recoton Advent Advent Q2035A 20" TV
Need to switch internet function on advent 4489
prees the funtion key ( blue Fn, bottom left ) and F11.
you may have to do this every time you turn on your netbook.
Jan 04, 2009 | Recoton Advent Advent Q2035A 20" TV
Dont know how to get webcam on for advent 4211c
Step 1: The "Tools" menu of Windows Live Messenger
1. Recover Windows Live Messenger in our software if you do not have it yet.
2. Start the installation of the software.
3. Once this is done, go to the Tools menu software.
In this menu, two links are important in order to properly configure your camera:"Setting audio and video" and "Parameters of the webcam."This is the first that we will discuss first and foremost, the second used primarily to adjust the parameters of the image in the secondary stage but we are dealing with. Launch therefore setup wizard and click on "Next".
Step 2: The setting of loudspeakers
1. Select your hardware in the menu.
2. Check the box if you use a helmet.
3. Test finally your sound output in order to adjust the volume.
It is possible that you find in the menu several choices. That means you have several elements in your computer capable of transmitting sound, a dedicated card and your motherboard, for example. In this case, make sure to select well the correct input, what you quickly verify the test by loudspeakers.
Step 3: At the turn of the microphone
1. Select your sound source.
2. Start talking to your microphone.
3. Observe the cursor, if it moves, your microphone is working.
Two remarks on the stage configuration. On the one hand, if your camera has no microphone, you must go through a device that you must annex plug into the pink on your sound card. On the other hand, if your mouse does not work, you may have selected the wrong input device sound. Take particular care in this setting and not leave this page only when the cursor s'agitera,
indicating that your voice is recognized by the software.
Step 4: Turning finally to the image
1. Specify this time the source of the video.
2. Observe the window of return: if your setup is satisfactory, your image should appear.
3. Adjust the frame rendering through the "Option" button.
Dec 25, 2008 | Recoton Advent Advent Q2035A 20" TV
How do I uninstall vista from advent t2250 laptop and install xp
Just Get the original Windows XP disc and boot the PC. It will just overwrites the XP over Vista and formates disc C. But the problem is might be that some new models are designed for Vista and after you erased it you might be having problems with downloading extra drivers for your laptop.
These drivers are included in your boot DVD which you got then buying the laptop, but they are Vista drivers. You will need to download XP drivers from microsoft website and sometimes there will be a compartibility issues
Good Luck
Dec 10, 2008 | Recoton Advent Advent Q2035A 20" TV
Advent 4211c web cam set up
Dec 08, 2008 | Recoton Advent Advent Q2035A 20" TV
Computer not working with Samsung LCD TV
Your PC isn't working, the "CMOS Checksum Error" is a BIOS error. It has nothing to do with the monitor.
You have to let the PC load the default settings and try to boot up, if the defaults doesn't work, you have to reconfigure the options in the SETUP program. To enter Setup press "Del" or "F2" in the POST screen.
May 05, 2008 | Standard (CRT) Televisions
Recoton Advent Advent Q2035A 20" TV Logo
48 people viewed this question
Top Recoton Advent Standard (CRT) Televisions Experts
Jaime Hernandez
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Recoton Advent Standard (CRT) Television Expert? Answer questions, earn points and help others
