Question about Vestax Pdx2000 Direct Drive Turntable System
Eratic platter direction and speed changes.
While cuing a record and/or trying to scratch, my platter began acting erratically. It reverses and speed ups and slows down, and generally acts crazy. It seems to have began gradually, but now the issue wont stop.
Any ideas?
Have you seen this solution (Padster07's), it solved my problem: http://www.fixya.com/support/t477894-vestax_pdx200_platter_keeps_changing
Posted on May 09, 2010
Califone 1435k This record player from the 70s runs great and came highly recommended but the 33 records we're trying to play are sounding much too fast. Any ideas on how to fix this?
This is an idler wheel drive turntable that uses a small rubber wheel, that when engaged pushes on the motor spindle and also on the rim on the underside of the platter. The spindle on the motor is stepped so as you shift speed the idler wheel moves up or down the spindle and that changes the speed of the platter. It could be the the shifting mechanism is dodgy You can try to loosen it by gently shifting the speed from 78 to 16 and back again. But the idler wheel rubber might be in trouble too.
Dec 29, 2016 | Califone International Audio Players &...
Trying to repair circa 1965 HMV "Imperial" Solid State record player. The turntable is not revolving at the correct speed so I want to dismantle and see if I can fix it or find what parts I need. So my...
There should be a "C" clip on the center post that holds the record in the middle. Pop that off and gently wiggle table up. Careful not to over stretch the belt. There could be a cover over the clip.
Jun 30, 2009 | Audio Players & Recorders
The turntable on the Crosley I have just brought,spins round unevenly(up and down),is this a problem as it plays some records ok but will not play others.
The platter should be level. If it is not then it could either be warped, by oil, heat affecting in the past. Or just faulty. Even if a warped turntable plays a record OK, it could damage it, as it is so easy for a record to be damaged, it could cause a scratch on the record. It should be checked out.
Feb 23, 2015 | Crosley Cruiser 3-Speed Portable Turntable...
My Gemini TT 02 gets stuck at 45 RPM. To get back to 33 you have to turn off and on again. Also the pitch is wildly out by about +7. Is there any way I can repair this?
Your terminology confuses.
Point 1. Why to you say, "Stuck?" Does it not make sense as a possiblity that the designers sought to prevent rotaton speed from being changed mid playback, especially on, say, an LP (long play) album with different side (stereo instead of 45 monaural) grooving. What would be the imperative of changing record speed in that manner...only one record type will play at a time. If changer, only one type record seriies can be played, all at the same speed.
Point 2. ...about "pitch...wildly out by about +7.
First, what are you meaning by pitch and by + (not -) 7. Since there is, to my knowlege, no record spin criterion known as pitch, are you referring to spin speed; hence to playback sound frequency, whether steady state or variable? If there is no user control of platter rotation speed on your unitn there would be little you can do other than to ensure all parts above and below platter are running smoothly with no drag or interference...possibly even lightening the record load on the platter, if a changer; and making sure records are clean to prevent slippage by washing with water or soap and water and air drying--avoid label. If your turntable is optically speed controlled (by timing marks on platter rim) those are typically adjustable to hasten or slow platter speed and therefore playback frequency pitch to your liking. "Wild variation" could reflect mechanical impedance as indicated above. Also check for record warping by trying known true record playback. Finallly, wild variation could be indicator of platter motor end of life cycle. Start pricing a motor if nothing helps.
I still don't follow the significance of the speculative(?) 7. Please explain if possible.
Sep 27, 2014 | Audio Players & Recorders
Stanton str8 60
The Stanton STR8-60 is a direct drive record deck, so this shouldn't happen unless the platter was damaged but after a little research I found that the Stanton's can get a faulty chip which is meant to regulate the speed and therefore can make it spin erratically.
Jun 14, 2013 | Audio Players & Recorders
2007 Chevy Uplander eratic speedometer. 4T65E Automatic Tranny.
there might be some "noise" in the speed sensor.i would recomend try a new one. but before i would ask the dealer if there were any tech. service bulletins that applie
Apr 10, 2010 | 2007 Chevrolet Uplander
Pitch is not working correctly
a) "dirty" main power switch, comes from sparking when power switch has been used a lot (happens also with some CD/DVD players - makes them loose some power - consequently, focus and/or spindle will not work properly). Try cleaning it up or replacing it (bypassing it will tell you if the switch is really the problem).
b) bad contact on the speed control slider (try moving it while slightly pressing it downwards, see if there is any change, if there is, have it cleaned up or replaced)
c) a problem with electronic speed control, possibly a loose solder connection or a bad capacitor somewhere in the speed control circuitry. If the circuit has fuses in it check if they are all ok. I once had a problem with a turntable that had a fuse "partially" blown (people were using the turntable a lot for "scratching" which overheated the fuse but hadn't blown it out, yet it changed in resistance from zero ohms to a few hundred ohms - the turntable began to **** and the speed was changing).
d) none of the above, it could be something else that i can't think of right now
hope ya get it workin'
regards
3rq8 (Triarcuate)
Jul 14, 2009 | Technics SL-1200 Turntable
Shifting problem
This sounds like a VSS (vehicle speed sensor) not being read correctly by the computer, or the VSS is inaccurate, erratic, etc. The erratic speedo seems to verify my theory doesn't it???
Jan 25, 2009 | 1994 Honda Accord
Sudden pitch change.
There is a speed control IC inside this unit that could be defective or the speed detect sensors could be faulty. WIthout seeing the actual machine it is hard to tell. This one is a direct drive if memory serves me correctly, so you should not have this kind of drift. With the unit only a year old, I would not expect a motor problem either. Can you tell if the drift is toward higher speed or lower? Or does it vary?
Dan
Jul 24, 2008 | Technics SL-1210 Turntable
Misfire and eratic idle on Ford Focus petrol 1.8i
motor mounts need replacement and sounds like your cars comp. is about to take a hit and go down
the air flow control unit sounds like it also has has a clog in it and needs to be serviced this is a big one when you get to driving at higher speeds the fan turns off and the air outside controls cooling air/fuel mixture rate sometimes too much air intake can make the vehicle act eratic
May 21, 2008 | 2000 Ford Focus
Open Questions:
See all Vestax Pdx2000 Direct Drive Turntable System Questions
Vestax Pdx2000 Direct Drive Turntable System Logo
300 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Electric Dime
Electric Dime
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
