Question about LG 50PX5D 50 in. Plasma HDTV
MY lg plasma tv has very small white dot in the background. IS there a fix for this?
I THINK ITS A DEAD PIXEL , YOU CAN'T DO ANYTHING WITH YOU DISPLAY , CHANGE THE PLASMA DISPLAY COST YOU MORE THAN HALF OF THE TV
Posted on Oct 19, 2009
We have white dots/spots on the screen what do ee do
the pixels are out adjustment x and y voltages are probably out You need a volt meter to check voltages they are marked on the inside panel
Nov 16, 2014 | LG 42PC3RA 42 in. HD-Ready Plasma TV
LG Plasma TV, 42
Hi that wold indicate a problem with one of your sustain boards. Most likelly the y-sus but it could be either one. You can find parts for this TV at www.interliquidparts.com remember when ordering parts you have to go by part number of the part.
Feb 24, 2012 | LG RU-42PX10 42 in. HD-Ready Plasma...
I amj thinking of buying a second hand lg plasma tv, but there is little white sparkly dots on the picture, mainly on the blackest bit of the picture. Is it worth buying it or not? thanx gill.
I realize that this is a old post, but for the sake of anyone else with this issue; I'm visiting my mother and found that she has the same issue. After some investigation, I've been told that this is an issue with something called the "Control PC".
The service tech told me that if it was colored dots, the issue is the "Y Sustain", but white dots are due to the Control PC.
Rough estimate for repair would be in the range of $300 - $400, for a repairman to come out and fix it.
Oct 14, 2010 | LG 42PX5D 42 in. Plasma HDTV
I get red dots in the black areas during dark sceens
http://www.retrevo.com/support/Maxent-MX-42HPM20-TVs-manual/id/278ag118/t/2/
www.scribd.com/doc/.../LG-TV-Plasma-Training-Manual
www.scribd.com/.../SONY-KDL42XBR950-TV-Plasma-Training-Manual
Use these links, user manual and two training manuals, these should help you isolate your problem
May 21, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
White dots in plasma tv
The only thing you can try is to adjust the tiny control on the Y board, if you want to try do this. Open the set , set it up so you can watch it with the back off. now looking at the back on the left side you will see a circuit board larger connected to a smalled one or two that go to the screen edge . on the larger board look for a few small controls, mark their positions with a dark sharpy then turn each a little while looking at the dots to see if one makes them better or worse. If one control effects the dots try to center it for the least amount of dots, if no effect is observed when a control is turned return it the original position that you mark before starting. if the dots do not clear either the Y board is bad or the whole scfreen is defective.
gd lk
Eric
Aug 15, 2009 | Televison & Video
Plasma tv has little red dots in the black
This problem (known as sparkles) can be cured by adjusting the ramp control on the Y-Sustain board. If this does not cure the dots then there is a software remedy for the control board which an LG repair centre could fix. Failing that a replacement board is required. The orbitor & whitewash are like screen savers to help to prevent a screen burn from a permanently displayed image.
Dec 31, 2008 | LG 42PC3D 42 in. Plasma Television
Lg plasma tv 42 px5d
Most times this can be corrected by the correct alignment of the diffusion. The unfortunate part is that will require a tech that knows how to set all of the power supply voltages and then align the diffusion pots on the ysus pwb. This could mean a defective ysus bd. but most times the alignment will correct this problem.
Mar 01, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 42in plasma - Green dots on HDMI channel
The diffusion is slightly out of adjusment. This timing adjustment is difficult and on a single scan LG plasma the proper operation requires voltage settings first, then a scope to finalize the adjustment. I have good luck with this alignment by eye but have had alot of practice. This will require taking the back off and a person with the technical background to set this alignment properly. Sorry no easy fix.
Feb 18, 2008 | LG 42LC2D 42 in. LCD HDTV
Red dots on a black background
Try to adjust the Vs down about 5-10V.
Jan 05, 2008 | LG 42PC1DA 42 in. Plasma HDTV
Flickering dots
The symptom you described is called diffusion. A simple alignment, normally in the power supply takes care of this problem. For the nearest Authorized Service Center near you contact Toshiba online at: http://webmail.tacp.com/service/servcntr.nsf/$$Search?OpenForm Hope this helps
Jun 03, 2007 | Toshiba 42HPX84 42 in. HDTV-Ready Plasma...
LG 50PX5D 50 in. Plasma HDTV Logo
277 people viewed this question
Computer Repairing
Computer Repairing
