Question about HP Pavilion zd8000 Notebook
System was to slow due to the BAD blocks on HDD
Search for "Process Explorer By Mark Russinovich" on Google and you will find fine monitoring program. Run it, place it so you can see line "Interupts" (it should be bellow "System Idle Process"). Continue to work normally and if line "Interupts" occupies significant CPU load (>30%) for a few seconds (>5sec) then you probably have same problem as I.
When I experienced extreme system slow down for the first time it was because the bad blocks. The MHDD (by Dimitry Postrigan) application found them.
When bad block are located they can be avoided using some partitioning software - in my case it was "fdisk" from Slackware CD. After this intervention speed was restored to the time when I have got this laptop 8)
Well, if MHDD find something bad be happy - you have found the cause!
This was my problem last year, now I have new HDD (two moths old), and MHDD tells me that HDD is ok, but system runs very slow (even without anivirus, firewall and anti-whatever). Now I do not know what is the problem. By the way I have HP Pavilion dv8000.
Best Luck tou You all.
In this (second) case slow data transfer was due to the usage of PIO mode instead of DMA. Only way to repair this was to reinstall the Windows.
Posted on Oct 14, 2009
    Brigadier General:
  • 4,044 Answers
Double check your system configuration and make sure you have properly identified the HDD to the system. Your initial problem may in fact have been bad clusters on your HDD but "fdisk" is a built in dos function. I would uninstall what ever software that you may think is identifying your problem and double check your virtual memory settings and then run HP Healthcheck WHILE you have anti-virus running. Aside from deleting cookies and making sure you don't have system processes running that you don't need you can look at increasing ram and fine tuning system resources.
Posted on Oct 07, 2009
Acer Aspire M5100 ..... Will not recognize EXE files (will not open most programs) ... Lags, freezes goes to blue screen and often completely and suddenly shuts of Everything (fan monitor etc.) except the...
This fault can be caused by so many different things:
You should start by tracing back through the recent history of hardware, software, drivers or settings changes to the computer between now and the last time that the computer was working properly to eliminate as many items as possible from the long list of possibilities below so you can isolate the precise cause.
Virus or spyware or other malware infection;Overheating due to insufficient number of internal cooling fans;Dry or insufficient paste between the Central Processing Unit (CPU) and the heat sink/CPU cooling fan;Failed or disconnected CPU cooling fan;Dust blocking input or output of cooling air inside the computer case;Dust blocking the input of cooling air to the CPU heat sink by the CPU cooling fan;Device conflict;Device driver conflict;Corruption of Windows system files;Corrupted Windows Registry during registry editing;Multiple installed anti virus programs in conflict with one another;Multiple installed Firewall problems in conflict with one another;Multiple installed anti malware programs in conflict with one another;Incorrect Firewall settings;Corrupted interrupted or incomplete Windows upgrade setup process;Corrupted interrupted or incomplete Windows repair installation keeping previous files and settingsCorrupted interrupted or incomplete Windows recovery operation;Corrupted interrupted or incomplete Windows Service Pack upgrade process;Corrupted interrupted or incomplete System Restore operation;Corrupted interrupted or incomplete Windows Automatic Updates shutdown configuration process;Corrupted interrupted or incomplete Windows Automatic Updates restart configuration process;Corruption of essential Windows system files by enabling compression to increase HDD free space;Accidental deletion of essential system files;Underpowered Power Supply Unit (PSU);Incorrectly installed Random Access Memory (RAM);Incompatible RAM;Incorrectly installed graphics card;Incorrectly installed expansion card;Internal devices incorrectly connected to the motherboard;Incorrect motherboard jumper settings;Basic Input Output System (BIOS) corruption;Incorrect device IRQ (Interrupt Request) settings in BIOS;Bad hard disk drive (HDD) sectors;Physically damaged HDD;Motherboard solder points short circuiting on a loose screw or a misaligned motherboard mount.
Aug 04, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
Why is my laptop so slow? And how do i reboost my laptop without a c.d
> Why slow?
1. dying disk-drive, that takes a few attempts to read each file;
2. not enough RAM to run "too-many" simultaneous programs;
3. computer-virus;
4. slow Internet connection.
> without a C.D. ?
Either telephone Toshiba, and order a replacement CD, identical to the one they supplied when you bought the computer. Or, look for a program installed on your computer that you use to "burn" new CD/DVD disks, to create the "System Recovery" set of disks.
Jul 12, 2011 | Toshiba Satellite L455D-S5976 Notebook
Slow computer
If your computer is made after 2006 then it is time for factory restore. Back up all files on disk or something. Then do a factory reset. This would take roughly 2 to 3 hours and make sure the laptop don't run out battery so keep it plugged in. As the laptop boots up hit F2 then after that windows pop up hit the advanced version (F8). Choose fix my computer and choose the factory or out of the box restore.
Jun 24, 2011 | Computers & Internet
My Zenga games on Facebook are only half loading. How can I fix this problem?
Usually try to refresh your computer by pressing F5 delete browsing history .
GO to tools > Internet OPtions > delete browsing history make sure s there's a checkmark on the password , filtering data and history or even cookies .Try to log on again .In case nothing happens used other browser ..such as Google chrome or mozilla
click the link below
http://www.mozilla.com/en-US/products/download.html
http://en.softonic.com/s/google-chrome-free-download - google chrome
in case still nothing happens probably you have a slow speed connectopn try to contact you r ISP
or remove unneccssary objects that may block your internet connection .Hope it help !!
May 26, 2011 | Facebook Social Network
Error 7 i cant open facebook
This error is most likely due to a problem with the Application folder on your computer during the installation process.
To resolve this issue, delete the Application folder, then try installing again. Follow these steps (for Windows):
  1. Go to the Start menu > Run.
  2. Enter one of the following commands in the text field, depending on your operating system.
    • Windows XP: %USERPROFILE%\Local Settings\Application Data\Google\Chrome
    • Windows Vista: %USERPROFILE%\AppData\Local\Google\Chrome
  3. Click OK.
  4. Delete the Application folder. If you're having difficulty deleting this folder, check for active Google Chrome processes on your computer and end them. Here are a few ways to locate and shut down these processes:
    • Press Ctrl+Alt+Delete on your keyboard and click Task Manager. Click the Processes tab and end every process that includes "google" or "chrome" in its name.
    • Download a third-party program called Process Explorer at http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx. Use its Find menu to search for "Chrome/Application," then end all resulting processes.
    Now try deleting the Application folder again.
  5. Once the Application folder is deleted, try installing Google Chrome again.
Well, I am new to fixya, so please don't forget to appreciate the solution.
Thanks.
Jan 27, 2011 | Google Chrome
Slow new page internet explorer
Do a google search for "google chrome"
If that runs slow you know its the PC, if it runs fine then you know its Internet explorer.
I no longer use internet explorer because it it so slow but i remember there was a setting which would scan web-pages for phishing threats.
Im not sure if its called that or if they have changed over to the smartscreen filter.
More info on smart screen filter here:
Microsoft smart screen
There are also some helpful tips here which could improve internet explorer perfomance:
Hints & Tips for internet explorer
I hope this helps
Regards
Mike
Mar 21, 2010 | Microsoft Internet Explorer 7
I can't remove sweetim toolbar
Hi
Many IE tool-bars are deliberately designed to resist removal,
behaving like viruses, because the companies who write them
get revenue from site visit counters. Also many of these tool-bars
infect your computer whether you ask for them or not.
(sweetim is categorized as malware by several watchdog sites)
1) The first step in removing it, is to download a good ad-ware
remover, such as:
Ad-Aware from Lavasoft:
http://lavasoft.com/products/ad_aware_free.php
or
Spybot Search & Destroy from Safer Networking:
http://www.safer-networking.org/en/spybotsd/index.html
2) Both of these programs are very good at what they do,
and they are absolutely FREE.
3) Please be extremely careful to go to the legitimate web
sites and download the "Real McCoy" because there are
hundreds of fraudulent sites out there pushing rogue
anti-malware programs with similar names.
The rogue sites promise you a free scan, come back
with a bunch of false positives, and then extort you
for money.
4) Scan your computer with both products and they should
remove the critter.
5) If that fails, you may want to try anti-virus programs,
such as AVG, McAfee and Kaspersky.
( I do NOT like Norton's)
All of these product cost money, but they do have free
trial downloads, and they are a good investment. You
only need one of these, I prefer AVG by Grisoft from
the Czech Republic. (Version 8 with firewall is very good)
7) Another very useful tool is the startup monitor & startup
control panel from Mike Lin's website:
http://www.mlin.net/StartupMonitor.shtml
http://www.mlin.net/StartupCPL.shtml
The monitor runs in the background and gives you
a warning message when a program tries to install
itself in the registry startup keys.
you can then choose to allow or block the action.
This will stop many bad programs in their tracks.
The control panel applet allows you to review and
manage all programs which startup automatically,
except for hooks and services.
6) If that fails, you will have to search running processes,
and search the registry to remove it manually
this gets complicated, and it is sometimes less work
to re-install windows, depending on your situation.
I don't want to get into that until you have tried
the other things.
7) Finally, I am concerned why you are still running version
3.1 of Internet Explorer, which is very old and has
virtually no security. You should be running at least
version 6 if not 7. (6 is better, 7 is bloated)
8) The best solution is to abandon Internet Explorer altogether
and switch to FireFox from Mozilla.org:
What version of Windows are you running ?
Let me know if you need more help
Martin
Jun 13, 2008 | Computers & Internet
Remove file
Here is more info on the critter:
http://spywarefiles.prevx.com/spywarefiles.asp?FXC=BHJI036815472
1) Reboot windows in SAFE mode by pressing F8 during the
boot repeatedly.
2) Use a virus remover like AVG or Kaspersky
3) Alternately remove the files manually.
4) If the files refuse to be removed, reporting a locked file
error, download a product called file unlocker:
a) unlocker1.8.5.exe or
b) who locked me from: http://www.dr-hoiby.com or
c) killbox.exe from: vbtechcd@gmail.com
d) File Assasin from:
http://www.malwarebytes.org/fileassassin.php
5) Any of these utilities will delete the file by brute foerce
if necessary
6) Download Mike Lin's Startup monitor (all 3)
a) Control panel applet
b) Stand alone program
c) Resident startup monitor
These three utilities will allow you to audit startup keys
in your registry and automatically stop rogue programs
from installing themselves without your permission.
7) Remove all suspicious programs from registry startup
locations:
HKLM = HKey Local Machine
HKCU = HKey Current User ....
Software\Microsoft\Windows\Current_Version ...
Run, RunOnce, RunOnceEx, Run SErvice, etc...
8) Install a reputable antivirus (with a license) and keep it
up to date:
e.g. AVG, Kaspersky, McAfee etc.
9) Disable most of the resident monitor function, because
these tend to slow your system down, BUT ....
Manually scan all downloaded files BEFORE
opening them
10) Download and install two free anti-spyware utilities:
AdAware by LafaSoft
SpyBot Search and Destroy
make sure you get these from the official sites,
beware of evil lookalikes.
11) Go to winternals WEB site, formerly Sysinternals,
and download security utilities by Mark Russinovich
(now at Microsoft)
Anti-rootkit and scanners for ADS
(Alternate Data Streams)
12) Go to F-Secure web-site, and download another anti-
root-kit utility called black light.
13) Download and install the Mozilla Firefox WEB browser,
never use Internet explorer (any version) except for
Microsoft updates
14) Install the following Firefox security plug-ins:
AddBlock Plus
ColorFul Tabs
Finkan Secure Browsing
Flash Block
Google Icon
NoScript (Very important, stops evil scripts)
Stop Autoplay
15) If you do all of the above, you will get very few viruses.
Martin
Jun 08, 2008 | Computers & Internet
Windows explorer
Both of the utilities you have listed have good reviews, but
there are three possibilities:
1) You have somehow damaged the windows shell,
explorer.exe, it's libraries or its registry entries,
while you ware cleaning your system.
In this case you will need to either re-install windows,
or at least repair windows from the install disks and
re-apply service pack 3.
2) You may still have a rogue program or a root-kit running
somewhere. Check the task manager (ctrl-alt-del),
shut down all unnecessary tasks. Then got to:
Control Panel ==> Administrative Tools ==>
Services,
and stop all unnecessary services, but do NOT
disable them, unless you know what you are doing.
they will re-start when you re-boot.
Download Mike Lin's startup monitor, and disable
all unwanted programs from starting up ==> reboot
Once you have trimmed your system to the bare minimum,
see if the problem persists.
You may also scan your system with rootkit detectors,
such as 'black light" and rootkit revealer by Mark Russinovich
3) You have a large corrupt media or picture file in your root
directory, and windows explorer is hanging while trying to
generate a preview thumbnail.
Disable: shmedia.dll = Show media
and shimgvw.dll = Show Image View
START ===> RUN
type:
regsvr32 /u shmedia.dll
regsvr32 /u shimgvw.dll
To re-enable pre-view, enter the previous commands
without the /u switch.
Martin
May 07, 2008 | Microsoft Windows XP Professional
HP Pavilion zd8000 Notebook Logo
155 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
