Question about Kirby G4 Bagged Upright Vacuum
Missing #15 Kirby Portable Handle for G4 - Kirby G4 Bagged Upright Vacuum
  • 54 Answers
Heres the link only 19.99 plus shipping http://www.totalvac.com/parts/K-675793ES.html?zmam=6843742&zmas=1&zmac=7&zmap=K-675793ES
Posted on Oct 06, 2009
Why does my kirby g4 sander not work
dirt inside or missing lubrication insite the bearings.
Jul 02, 2014 | Kirby Vacuums
How do I use my kirby without upright handle, where do I put the bag?
The bag is left where it is. The hose goes on the front of the vacuum after removing the nozzle. See the How to Attach the Hose instruction video on the below site.
http://www.kirby.com/Portals/0/videos.html
Mar 06, 2011 | Kirby G4 Bagged Upright Vacuum
G4 transmission does not engage going forward
The handle pivot is set too far back on it's slide. It will be necessary to remove the handle, switch plate, and upper motor shell to access the slide. Two large phillips screws hold the pivot assembly to the slide. The pivot must be loosened and moved ahead very slightly, while centering the slide in place.
Jan 13, 2011 | Kirby G4 Bagged Upright Vacuum
I've owned my Kirby G4 for 15 years and never had to touch it for maintenance. Should I ever get it overhauled or tuned up?
Kirby recommends getting it serviced yearly but if you are mechanically inclined you can service it yourself. the biggest thing is cleaning and blowing all the dust out of the motor and inside compartment. also check your motor fan for chips nicks, and stress cracks around the center. Inspect the bearings and motor carbon brushes for wear and noise. and put some 3 in 1 oil on the top handle slide assy on top of the motor. do not disassemble this unit there are many way bearings inside and if its not reassembled just right it will throw off your self propelled unit
Jan 03, 2010 | Kirby G4 Bagged Upright Vacuum
I have a senteria about 4 yrs old. it bounbes
Check the wheels and axles for damage or bent shafts. Remove the bottom cover and inspect the brush roller for damage--breakage of the roller, bad or broken end bearings, missing brush sections, or something stuck to the roller like a wad of gum or something. Hope this helps!
Dec 26, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby G4 causes black streaking when shampooing carpet
Replace the belt it is probably worn. You can get a replacement here:
Kirby G4 Belt
Dec 06, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Toe-Touch Control pedal jammed
Flip the Kirby over,and you will find screws that hold the front axle in place.Remove the screws and the front axle.Debris may be caught in the mechanism.Clean the debris out,and use WD-40 to lubricate the mechanism.May be able to do this without removing the axle,but removing it allows for better cleaning or for identifying broken or missing parts.
Dec 14, 2008 | Kirby G4 Bagged Upright Vacuum
KIRBY G4 FAN ASSEMBLY ORDER
First put the gasket on the spacer, thin end to to out, push it down all the way on the motor shaft, then put the nylon washer on, then the fan, metal washer and then the pulley, just snug it, (don't tighten too much just beyond hand tightening). Put the casing, top and handle back on.
Feb 01, 2008 | Vacuums
Kirby G4 Bagged Upright Vacuum Logo
71 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
