You may have a problem with the screen's back light. It could be a ballast that may go bad or the light itself may go bad or loose connections in those areas may cause it. Check as well the data cable or check if a different cable would work.
get new driver for NL C27C1 I would like to get the manual and or info on how to get a full screen....
(More)
get new driver for NL C27C1 I would like to get the manual and or info on how to get a full screen. I have 3 inches on both sides that are black
I just got an acer p235h monitor it is currently hdmi and my second monitor is vgi, the acer display...
(More)
I just got an acer p235h monitor it is currently hdmi and my second monitor is vgi, the acer display does not stretch across the entire screen
I just got a used hp pavilion 150..I am computer stupid...does it need a power cord or does it get...
(More)
I just got a used hp pavilion 150..I am computer stupid...does it need a power cord or does it get direct power from a apple computer...if so, where can I get one...thanks...Rob
The buttons located on the front of the monitor are not working nor are they stuck. The brightness...
(More)
The buttons located on the front of the monitor are not working nor are they stuck. The brightness display is permanently fixed on my screen and I am unable to remove it. When I unplug the power cord that is attached to the monitor, the brightness display of course disappears, but within half a second it re-appears when I plug the cord back into the monitor. Also, when the brightness display first appeared, it decreased from 100 down to 0 on its own. I am at a loss as to what the problem is or how to solve it.
