PC comes on but it does nothing. No beep and nothing on my screen
System fan comes on but nothing comes out of my screen. memory, processor, psu and other removable parts has been tested to other unit and they are all working. I think it's the motherboard, what could be the problem?
    Scholar:
  • 67 Answers
Check if there are any blown or leaking condensators on the board. It is a very common problem and easy to fix for someone with some skills. If you do not find anything most probably is some microcircuit defective and it is not worth it to investigate more.
Posted on Oct 06, 2009
On start up fan runs, no beeps, black screen, no response from keyboard & mouse. Unplugged everything for 30 minutes, then tried again, start up began then went to black screen, no keyboard, no m
in your case, there might be some problem with the main board.
usually no beeps will related to the processor error / mainboard error / ram error / PSU error
to check the processor : try to exchange the processor with the same type.
to check the Memory: try use rubber eraser to clean the cooper plate of the memory. then plugged it again.
in case if there is a power supply error, then try to exchange the power supply using other PC PSU.
if all steps above are checked, the problem might be at the mainboard. in that case, replacement will be the best option.
Jan 20, 2012 | Acer Computers & Internet
Pc wont boot, MCP73PVT board, i have checked the ram, processor, heat sink and psu,cmos batt and still no joy, its starts for 4 seconds and turns off, all fans come on but nothing else no beeps
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 21, 2011 | Packard Bell (181368) Motherboard
Hi my hp pavilion laptop DV5000 on start up has black screen and one long beep then 3 shot beeps then one long beep and another 3 short beeps. The lights stay on but nothing happens. The pc has been...
first remove the cover of your computer after switching off the system and removing the power plug the power the system and see whether the processor fan is working if not power off the system and remove the 24 pin connector from the smps to the motherboard and short the green and black pin of the conector from the smps and see the smps fan is working if not replace the smps if working then remove the memory from the slot and clean them or change the memory to which match the dimm slot an connect the connector and switch on the computer
Feb 26, 2011 | HP Pavilion M9040N Elite Desktop PC
Power and fan run light flicker in front does not boot up
Relace the psu it's a dodgy Bestec ..replace it with a winpower psu 400 watt , they are cheap but they work better.
Mar 28, 2009 | E-Machines T1842 PC Desktop
Computer wont boot, only fan running
check the (memory) ram chip, keyboards, and mouse for faults then try again.
Most time beeps indicate memory errors
Jan 17, 2009 | Lenovo ThinkPad R61i 14 inch widescreen...
Loud fan blank screen andthe fan is lousd.
check your memory, processor, PSU (power supply) and your motherboard, any one of these components could be the problem, if its intel it will be the processor or motherboard, if its AMD its no doubt memory or PSU. quick way to sort the problem in most cases is to reset the cmos/bios, this is situated near the battery on the motherboard in the pc ( if you have it right the pc will not turn on when you press the power button ) put the plastic jumper back in the possition you found it and restart your pc. if that doesn't work then look into what i said above
good luck
PS use a torch to see where the cmos reset is
Nov 14, 2008 | Compaq Evo N1020V Notebook
Only fans are starting - nothing else
Have you checked the CMOS/BIOS Battery? How about reseting the BIOS jumpers?
Test the system using Motherboard with processor and 1 RAM, just connect power and screen only, switch it on. It it fails try another memory... Whether the memory, board of processor is the problem.
Fixya me when done....
Post me back if it doesn't work...
Feb 08, 2008 | Gigabyte GA-965QM-DS2 (rev. 2.0)...
A7V8X NOTHING HAPPENING,
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Nov 07, 2007 | ASUS A7V8X Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
