Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Hallway closet door opens by itself
The door to a walk-in closet opens slightly from the closed position constantly. I have tried pushing on the door, wiggling the knob, pulling it, etc but I am unable to replicate the problem. Why would a closed door do this?
We have an a/c blower in a closet next to this one, which causes a vibration. I'm thinking that could be the culprit, but I still do not understand why the door doesn't open when I am messing with it. Any help would be appreciated. Thanks
    President:
  • 3,197 Answers
Remove the hinge pins and you can use a hammer to put a slight bend in them. Tap them back in place.
Posted on Oct 20, 2009
Why does the power window button blink on and off and the automatic feature doesn't work in the 2008 Toyota Sienna?
NOTE:
Anytime the batteryterminal has been disconnected, please initialize the driver's door power windowand front passenger's door power windowafter reconnecting the batteryterminal.
With ignition switchin the "ON" position, do the following:
1. Push down and hold the driver's door power windowswitch to completely open the window.
2. Pull and hold up the driver's door power windowswitch until the window closes.
Continue holding the switch for approximately one second until the switch changes from blinking to a constant illumination.
3. Check for proper operation of the "one-touch open and close" function by fully pushing the switch briefly to the "DOWN" and "UP" positions.
At this time the power window switchfor the passenger's door windowshould be blinking.
4. Push down and hold the passenger's door power windowswitch to completely open the window.
5. Pull and hold up the passenger's door power windowswitch until the window closes.
6. Check for proper operation of the "one-touch open and close" function by fully pushing the switch briefly to the "DOWN" and "UP" positions.
Feb 09, 2016 | Toyota Cars & Trucks
WHERE IS THE CIRCUIT BREAKER FOR THE MICROWAVE AND THE WALL OUTLETS
Good morning Richard.
The location of the circuit breaker will depend on the house, or building that you're in. Generally, they will be all together, often in a stairwell or a garage/basement wall that won't be obstructed. If the electrician followed code, the breakers should have labels on the inside of the breaker panel door, telling you which breaker or breakers service the kitchen. Often, if the microwave is an installed type, it'll have it's own 15 or 20 amp breaker.
Good Luck!
Nov 19, 2015 | Microwave Ovens
Freezer door opens
This sounds like an alignment problem. Loosen the hinges slightly and place the door in the closed position and duck tape it in place. Tighten the hinges and check it for seal. Door is heavy by itself so empty it first and work with some help.
Apr 01, 2014 | Maytag MSD2732GR Side by Side Refrigerator
Favorit 40010 vi dishwasher the machine door opens during the wash except on eco 50 wash
Strange it remains closed on one stage? Usually a door that opens by itself is due to misalignment, and then gain water will leak onto the floor. If someone banged into the side of the door and moved the washer a slight bit, the locking tab under the work counter may not be in a positive position. If the tab is bent slightly up, the door may barely make contact and lock when in operation. A simple movement of the washer could pop the door open. Other than that, any electrical dysfunction would require a professional servicemans attention.
Mar 17, 2014 | AEG 23 in. Favorit 44070Vi Built-in...
How do I open the DVD/CD Loading Door? It will not open!
You have a physical problem---make sure front of unit is not touching the door or out of position----
May 22, 2012 | Televison & Video
Door will go down until it gets close to the sensors (transmitters) and then it hesitates and goes back up. One of the sensors has a constant green light which tells me that it works properly, but the...
The sensors have to see each other in order for the system to work. If the beam is interrupted, it will cause the door to go to the open position. It sounds like the sensors are out of alignment. When the door is closing, it moves a sensor slightly and this breaks the beam, door reverses and opens. Work the sensors so that they are both aimed perfectly at each other. I believe that the amber light will change to a different color when the sensors are aligned.
Jan 29, 2011 | liftmaster Chamberlain Garage Door Opener...
I have a liftmaster Model 1240. Door will open by remote or wall opener. The door will only close while holding wall opener button down. If i try and close via remote, light starts blinking and door...
The only thing that will cause the main light to flash 10 times and the door to reverse to the open position is a sensor problem. Make sure the light on each sensor is on and not flickering ever so slightly. Make sure they are not moving when the door starts to close. Lights on sensors should not blink. One light should stay on constantly and the other sensors light should go off when you block the sensors.
Jan 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door will inconsistenly not close
It is normal for that LED by the learn button to flash randomly. It can also flash a code to help with diagnosis. The codes are 1 to 6 flashes followed by a pause and then repeats. A rapid flash is a sign it is receiving a radio signal but not necessarily the correct one to operate the door. If when your door doesn't close properly the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. The sensor must be pointed at one another and sometimes can be off just a hair and will cause intermittent problems. A slight tweaking of the sensors will cure this problem. The 'down force' adjustment can be set too low and cause the door not to close sometimes. This can be increased to overcome this problem. This problem will not cause the main light to flash. The other possibility is the RPM sensor. This is the printed circuit board that senses when the door runs into something. I have never seen one intermittent but that doesn't mean it's not possible. I hope this helps you.
Mar 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
TX - SR606 and Dish Network 612 HD
Hello, sorry but we do not have any additional codes. Thank you, Onkyo USA
Mar 28, 2017 | Onkyo TX-SR605 Receiver
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
182 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
