Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Has odor and mold - LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$#@!
Posted on Sep 28, 2010
Want to remove odor from dryer
Hi photoed1
The odor that you are experiencing may be from the growth of mold.
Inside the washer, some small pool of water may be left standing and is harboring mold spores.
Even though you may operate the washer regularly, the mold spores are not being washed away.
Here is a couple tips that might help to eliminate odor issues in your washing machine.
First, and the most effective is to, leave the lid or door to the washer open.
By leaving the door open, it promotes air circulation and evaporation of standing water.
The reduction in odor occurred quickly and dramatically.
Another tip is to run the washer empty for a quick rinse cycle.
Add an entire cup of bleach at the start of the cycle.
The bleach is effective at destroying organisms, such as mold and bacteria.
However, running it once will not be completely effective.
I suggest pouring another cup of bleach into the wash tub, after the cycle has completed.
This will leave bleach as the standing pool and should prevent the growth of mold or bacteria.
However, if you do this, before doing a load of laundry you should run an empty rinse cycle again,
to avoid damage to the clothes from the bleach left standing in the wash tub.
Please take time to rate me
Bud
Apr 18, 2013 | GE Dryers
After cleaning the refrigerator still has a strong odor. It also grows mold.
put an open box of arm & hammer baking soda on the top shelf that absorbs the odor. The mold is a byproduct of the odor.
Jan 24, 2011 | GE Monogram ZIR36NMRH Refrigerator
My front loading washing machine has a musty odor. what can I do?
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle(on hot water cycle). Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
  • Additionally, inspect the door gasket for gunk or mold. Clean the gasket well. This is another gathering spot of bacteria and mold growth.
Jun 28, 2010 | Kenmore Washing Machines
Odor problem
clean the front gasket on the door with Tilex, they get mold and midew, also run a tub of hot water with some Tilex brand mold and mildew remover through it, then run a second washer tub to clean Tilex completely out, u will need to do this about once a month, and yes all fron loader have this odor problem.
May 20, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My a/c has a strange odor like moist, mold. How
First, have your A/C Microfilter replaced-located behind the glovebox----it is probably the source.
Feb 22, 2010 | 2009 Honda Accord
The washer emits a foul odor when washer first
You have the beginning of a detergent and/or softener residue buildup on the inside of the plastic outer drum of your clothes washing machine. Mold and bacteria need a moist, dark environment and a food source to grow. This residue is the food source. This can be a major health concern. See: http://www.cbsnews.com/video/watch/?id=5408971n
We can't change the environment of the washer but we can lessen the "food source" by reducing detergent and fabric softener use.
Do an internet search on "Smelly Washer Reviews" to see what you can do about the problem of mold odor in your washer, towels and clothing.
After your washer odor is gone you'll need to change washing habits so mold and bacteria don't return. Go to the blog page at smellywasher.com to read the featured posts on the left side of the page on the cause of the problem and what to do for extreme cases of washer mold odor.
Dec 19, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Clothes dont smell clean after washing them
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 25, 2009 | Maytag Washing Machines
My front loading washer has a smell????
Oct 19, 2009 | Whirlpool Washing Machines
Odor coming from inside washer
There is a tub beyond the tub you see. Run a load of water with chlorine bleach. This will kill the mold & mildew spores that are causing the odors. ****Do NOT add clothing to this washload****
If possible, keep the door open when not in use. This will allow the inside to dry and mold & mildew cannot grow.
Jul 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore Washer Odor
Meoser,
I've been selling the only available all natural washing machine and towel mold and mildew remover online at smellywasher.com since 2006.
It's now also available at Ace, Tru Value, Hardware Hank and Do It Best hardware stores. One bottle provides 24 treatments and guarantees to remove mold, mildew, or any odor from your washer. After the washer is cleaned it also safely and easily gets rid of the mildew smell from any towel or clothing that the odor has transferred to.
The dark, moist environment of your clothes washer is the perfect place for mold and bacteria to grow. See: http://www.cbsnews.com/video/watch/?id=5408971n
We can't change that environment but we can stop the food source for them to grow buy reducing the amount of detergent used and stopping fabric softener use. Go to the blog page at smellywasher.com to read advice on the cause of and cure for washing machine and towel odor.
Nov 06, 2007 | Washing Machines
Washing Machines Logo
126 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
