Turns on and off automatically. (Won't turn on - blue light then orange light, then off and on again)
informatica
  • 1114 Answers
SOURCE: Analog Power Saving Mode
Firstly check the connecting cable from the screen to the computer at both ends. Ensure that the thumbscrews that keep the connector in place are tight. Has the PC been moved recently? Any chance the cable could have been put in the wrong place? You can get the installation manual on the following link to see where that cables should go: http://us.lge.com/filedown.do?filepath=1000000757&fileName=L1750B-BF.pdf Try resetting the monitor by pressing the "Auto/SET" button on the front panel for a few seconds with the PC on. If that fails you can do a full factory reset on the monitor by using the on screen menu and navigation to the "reset" function on the setings (gearwheel) page. This is described in the manual page A12. If all this fails then disconnect the cable to the monitor, the monitor should display "no input signal" if it does suspect the PC graphics card is faulty.
Posted on Jul 30, 2007
  • 51 Answers
SOURCE: Television automatically turns off after a couple seconds
there are 2 fuses -24v and 24 v normally would go out because
covergence ics failled . That would be a shutting down problem cased by missing those voltages.so you would need to replace those 5A (small green fuses) , you would need some kind of soldering and unsolderin skill) and the ics are stk392 570.two also. open the set from the fron ,taking speaker grill off and then the wood board behing (4-6 screws) you the the board in the center big metal heatsink. you would need to work from the back to repace those puppies.hdtvman
Posted on Jul 01, 2008
  • 5 Answers
SOURCE: my camara won;t turn on everytime i get a orange
charge the battery until light changes from red to green, then when you put the battery back into the camera make sure you push the battery all the way down until it locks in place. Hope this helps
Posted on Oct 10, 2009
SOURCE: When I turn my computer on the monitor stays off.
or just plug the video lead into the onboard connection (vga) if that doesnt work try hitting f1 when your pc is loading as sometimes the bios may be set to run in pci (graphics card) but will tell you at startup to press f1 to continue but you wont be able to see that message as its still in vga mode at this point ? i hope you understand me sorry lol, on my pc i hit f1 after 1 minute of loading to allow the computer time to get to the loading screen (which we cant see) then i know that when i press F1 the screen pops into life after about 15 seconds try it
Posted on Mar 12, 2010
budmrtn
  • 11361 Answers
SOURCE: monitor lights up for approx 3 seconds turns off
Look for bad caps in the power supply section.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jul 11, 2010
How do I reset my Amazon Echo.?
  1. Use a paper clip (or similar tool) to press and hold the Reset button. You can find the Reset button at the base of your device. After you press and hold the Reset button, the light ring on your Echodevice turns orange, and then blue.
  2. Wait for the light ring to turn off and on again. The light ring then turns orange, and your Echodevice enters setup mode.
  3. Open the Alexa app to connect your device to a Wi-Fi network and register it to your Amazon account.
Jul 19, 2017 | Amazon Computers & Internet
Playstation light turns orange to blue then white
Same as with the Xbox, If the HDMI is not connected to a TV, that is what it will do. Nothing is wrong with it.
Mar 02, 2014 | Sony Playstation 3 (PS3) Console
The playstation 4 the light on top of the playstation 4 turns orange to blue and then white
Sounds like my first unit. Blue light of death. Contact Sony for help and/or replacement.
Mar 02, 2014 | Sony PlayStation 4
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Hp 6820s will not power up.
Try removing the battery and see if the light is normal.
If so, you may need to replace the battery.
Sep 28, 2009 | HP Computers & Internet
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Same Problem As Well
microcontroller needs to be changed
Jul 07, 2009 | Harman Kardon AVR 7300 Receiver
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
