Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Power light is red. Hub is OK. No wireless and Internet connects
Power light is red. Hub is OK. No Wireless and Internet connections
    Genius:
  • 1,269 Answers
Have you tried configuring your wireless settings? If your internet works hard wired, its just the wireless settings that need to be configured. Access the router's setup by going to http://192.168.0.1 and change the wireless channel. Make sure to check the wireless security as well and verify if you are using the correct wireless network key
Posted on Oct 06, 2009
My D-Link dap-1160 is not working
For routers not just the power light that should be lit. Are you using a modem/router? If so, there should be a DSL,INTERNET,WIRELESS light indicator as well. If the DSL light is OFF,steady red, OFF there might be trouble with your line connection. Call your Internet provider. Also, check cables (yellow cord, gray cord, telephone cord) that should be connected tightly to where it supposed to be connected.
Feb 26, 2013 | D-Link DAP-1160 802.11g Wireless G Open...
Hi I have a RangeMax - and it has always been working fine. Last week I couldn't connect wirelessly, so I reset. Nothing. Now I've tried connecting wired through the hub - still nothing. The power is...
Can you please check the signal strength of the wireless router.
If you can log into the wireless router management page and check for the erros if any inside the logs.
Oct 30, 2010 | NetGear RangeMax WPN824 Router
For some reason the light above the WPS button keeps flashing red. I have tried multiple reboots, none of which have worked. when connected to the ethernet modem, the light stays as a solid red color.
You need to reset your Router before setup manually.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Aug 16, 2010 | Belkin Wireless Play Router (F7D4302)
We cannot connect wirelassly
...I'm not sure on what your actual question is here but make sure you have a wireless network to connect to (you can buy wireless router and an internet service via any internet service provider- I use BT)
If that's not your problem (which i don't know what is) - then make sure your typing security WPA key in properly. (WPA key should be located on the back of your router/hub if that wireless hub got delivered by your current internet service provider). If your still having trouble contact your current home network manager (dad/mum/guardian/employer/lanlord) who has software to control the WPA & what it is).
Your xbox should have a network adapter already installed (device inside that allows connection wirelessly to a networks wireless router/hub). So that shoulden't be the problem (unless your xbox is broken)
Apr 11, 2010 | Sony Playstation 3 (PS3) Console
Need help connecting xbox live to the internet, have the wireless router but nothing is successful
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :)
Dec 29, 2009 | Microsoft Xbox 360 Console
The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
Try turning off the router for 30 secs, then power it up again.
Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
If you can connect to the Internet then -
With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
Also install the latest wireless card driver.
Then test the wireless and Internet connection. If this doesn't work -
Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
Cannot connect to internet via wireless hub to laptop
When you power up the wireless router and the LEDs are ON then the router appears to be OK and this also applies to the DSL or cable modem.
To check if the modem is configured to your ISP settings and connects to the Internet, connect the modem with a LAN cable to your laptop and check if you can connect to the Internet.
Next, the wireless router needs the wireless settings configured and then configure the wireless card in the laptop with these settings so it can communicate with the wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 14, 2009 | Computers & Internet
I have a wireless connectivity issue from my laptop. When the power cable is connected, the internet works. When I disconnect the power cord, I am disconnected from the internet. This problem has only...
I would say you need a new battery, if when you disconnect the charger your losing your wireless connection, you need more power to hold the wireless connection or that make sure when you remove your charger press your wireless button near your volume control on laptop to make sure its on, blue, not off red ok
Jun 29, 2009 | Acer Aspire 3680 Laptop
How can i connect my laptop to internet without router device via desktop pc connected to internet
you could its called an ad-hoc connection..but youneed either a wireless adapter on your desktop or a network hub
Apr 29, 2009 | ASUS Wi-Fi@HOME (WIFIG80211G) 802.11g/b...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
441 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
