Question about HP Officejet 5610 All-In-One InkJet Printer
Paper is no longer feeding into printer. - HP Officejet 5610 All-In-One InkJet Printer
SOURCE: Samsung ML-1651N Printer
I have the exact same problem with my ML-1651N printer. It started out as an annoying problem that i solved by pulling the paper try out and then pushing it back in again. Now that solution doesn't work anymore.
Posted on Aug 24, 2007
SOURCE: no longer prints envelopes from manual paper feed
you need to change driver configuration
very easy
elvis
Posted on Apr 18, 2008
romeo1790305
  • 17 Answers
SOURCE: Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Posted on Jan 29, 2009
SOURCE: printer no longer feeds paper from paper tray
Remove the paper tray. Use a lint-free cloth dampened with rubbing alcohol (isopropyl) to wipe all around the black "rubberish" wheels right underneath the unit where paper tray goes. I learned that by calling Okidata.
Posted on Oct 10, 2009
  • 89 Answers
SOURCE: Paper No Longer Feeds
try to push the paper in as you print. this is just a work around. you can check the rubber on the paper feed tray or the whole thing might need replacement
Posted on Mar 14, 2010
Not feeding the paper
inside the printer has to be a roll that takes the paper and get's it into the printer try to wipe that roll with some technical alcohol, i hope this helps you.
Jun 17, 2009 | Samsung SCX 4521F All-In-One Laser Printer
No longer feeds the paper correctly when trying to print. It seems to feed the paper at an angle. I can hand feed one page at a time but still isn't straight. What can I do?
Please try to reinstall the your printer driver. Usually the driver is the one which malfunctions.
Good luck.
~regards,
Jegan
Jun 03, 2009 | Dell Office Equipment & Supplies
Paper jams no matter what stock I use; Lexmark e232
Slipping paper feed rollers is probably causing the jamming. Remove the paper tray and tip the machine back so that you can access the feed rollers from underneath. A good technique to isolate this problem is to remove the rubber feed tires, turn them inside-out and refit them. If it now works OK you need to get new feed rollers.
Jun 01, 2009 | Lexmark E232 Laser Printer
Jan 29, 2009 | Epson Stylus CX3800 Printer
My printer no longer feeds in Epson Premium Glossy paper S041624
Try to clean the paper pick rollers with a cloth, dam it with little water and try to hange the paper settings by going into printer preferances.
Regards,  raj_p5983
Jan 20, 2009 | Epson Stylus Color 1160 InkJet Printer
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Printer problem
Sometimesa feed roller can become smooth and it no longer grabs the paper.
If you ahve some emery cloth try to rub it gently on all rollers to roughen them up a bit.
Jul 05, 2008 | Canon PIXMA iP1600 Printer
No longer prints envelopes from manual paper feed
very easy
elvis
Apr 01, 2008 | Brother HL-5240 Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
