Question about Kitchen Ranges
On a Norge Stove where are the fuses? - Kitchen Ranges
Where can I buy a Norge model 6498xvs control board. Thanks!
You can try a local appliance parts supplier, but the odds don't favor being able to find the board or an equivalent part because of the age.
Feb 12, 2016 | Kitchen Ranges
Defy 731 multifunction oven stopped working
switch as probably burt out so that the connecors inside dont touch anymore, or your supply fuses for the stove have blown, check your fuse box. but at any rate if there are sparks i would replace stove or get in a qualifed person the check your stove.
Oct 22, 2014 | Ovens
How many ohlms on thermo fuse test ?
Zero, should just have continuity, if there is no continuity the fuses burnt
Aug 09, 2014 | Maytag Dryer Repair Part - Dryer Lint...
Moto guzzi problems
What do you mean adjust the display? I have a Norge and other than changing the display functions I am at a loss. You should be able to get these issues resolved in the manual. My Norge has a great owners manual that came with it.
Jul 14, 2014 | 2014 Moto Guzzi Norge GT 8V ABS
I have a Norge 3H9TZ-EV stove. The oven & broil elements stopped working suddenly & there are no fault codes. Power to the stove is good, there are no blown fuses and nothing visibly wrong with the...
I had a similar situation happen to my GE Stove. I tested the incoming wires and found power on both. I couldn't find anything wrong either.. What I did find though was that the Circuit breaker itself had "half died", meaning that only one pole of the dual circuit breaker was working. I tried resetting it over and over only to find that it was completely fried. I went to the hardware store and got a new circuit breaker. I first looked for any loose wires on the elements and the burners of the stove that could have provided a ground fault, and after finding none, I installed the new breaker and flipped it on after plugging the oven back into the wall. Voila! everything worked fine! Installing a new breaker can be scary at first. you may want to consult a professional to check the breaker for you. Or if you are comfortable doing it yourself, then go for it. At least you'll know if the breaker is good or not. Once I had the breaker off of the circuit panel I checked it for continuity with a voltmeter and found only one side working. The panel I have allows you to just "pull" the breaker straight off of the panel. Some are screwed in, some are popped in, it just depends on the manufacturer. So, based on my experience, that is what I would do. Perhaps it's the wall outlet, but I doubt it. If you want to check that, use a voltmeter to check each incoming wire for proper voltage. Some symptoms I had with my oven were the panel would be on and would "click" like it was turning on the oven, but nothing would happen. Or the Burners would work, but only heat up halfway. The Broiler wouldn't even come on at all. Let us know how it goes!
Oct 25, 2013 | Freezers
Admiral dryer
You pop the top by using a putty knife to release clips on either side. The innards are like that of a Norge style dryer. The heater is small on top with the fuse mounted on the right side of it. The main thing that goes out on these is the plastic blower wheel. It can get loose and cause heating problems improper airflow and such.
I did a crappy phone video of a blower replacement on a Monkey Wards Norge Admiral dryer HERE
Jul 20, 2012 | Maytag Dryers
Freezer of the refrigrator is not freezing. Norge,
sounds like the cold coil is freezing up and this is a defrost problem.. ck the defrost themo/ and the heater . / may also be the defrost timer . but every 3 mo ( i would think the defrost terminator is failing .. ) mm
Aug 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I reset all controls and a few minutes later the
Write down thew model# and serial #,go online, look up the wesite for Norge, and find/download the manual. They might sell one also. If not contact them directly and ask them. Maybe the dealer who sold it to you will have a manual you can look at.
Mar 31, 2010 | Kitchen Ranges
Paint Specification
Try your local Factor paint auto store they have codes and color eyes to match it good luck
Mar 25, 2009 | 2007 Moto Guzzi Norge 850
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
