Question about iLO 2600 Television
Reset when the movies or whatever is playing and ya know how sometimes it stalls or gets goofy from the channel itself, and the TV resets its self....well mine wont reset it just stays in that state. It will do it to another tv when I changed it but it will keep reseting it and get out of it. I am pretty sure it has to do with my cable box now that it does do this to other TVs but my flat screen ilo won't...what can I do to fix this problem
    Genius:
  • 1,554 Answers
Since you are using a cable box
try using hdmi cables or component a/v cables
when using them as you will get a stronger picture less video noise
and stereo as the cable box does not output stereo on ch 3/4
I would also have your cable reworked if you have failing videos on the upper tier channels.
Posted on Jan 31, 2008
How to watch Google play movies and TV shows on Roku?
• Visit channel store and search for the Roku Google channels.
• Choose the add channel option from the Roku Google play movies and TV application that is selected.
• Sign in by choosing option "go to the channel".
• Open your computer or the mobile device.
• Use the option play.google.com/roku get ready to enter the respective code which is displayed on the Roku screen.
• Follow the on-screen instructions.
• Payment mode is selected and a Google pin is received.
• Return to your devices and search for the Google contents.
• In case the Google Pin is forgotten it can be reset signing in again.
• The Google account used can also be changed.
• The Roku account activated using Roku activation code link is compulsory before counting on these procedures.
Connecting Google channels to Roku device can be done with extensive support by calling toll-free number +1-888-269-1011 and the network support team availed at the end would assist you better. More updates are provided at www.go-roku.com.
Oct 09, 2017 | Televison & Video
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
Stuck in vedeo mode wont play movies dvd or vhs.dont have a remote can i reset or reprogram the tv to play movies or at least get back to regular channels
Tries this go to the tv set itself presss the channels up or down u will get out of the video modes line1 or line 2 u will get out to regular tv signal.If u need a new axact remote go to this website.1-800-Remotes Factory original.
Aug 24, 2009 | Zenith B27A11Z 27" TV
I'm having difficulities with a RCA entertainment series television. A little while ago my T.V started going crazy. For example, Sometimes when i go to turn it on to change the channel it will say panel...
Best Way reset the set,U right it well reboot itself,before u go to sleep unplug the tv,take out the bateries to remote.Morning,plug in and put the bateris back might reset it self.
Aug 17, 2009 | RCA 32F531T 32" TV
My 53H71 Toshiba TV all of a sudden started blinking
There is a problem in the control board and the unit is doing self diagnostics.  Since the problem occurs again the board is unable to fix itself and needs service.
Jun 02, 2009 | Toshiba 53H71 53 in. Rear Projection...
Channels are locked HELP anyone
Call Dish at 800-333-3474 and ask them to reset the parental control password and this should unlock the sytem for you. It has been awhile since I had this issue. If you can't access channels yet go to the menu and go to locks and then it is pretty self explanatory but if you have issues let me know. Thanks for using Fix Ya.
Apr 15, 2009 | DISH Network ViP622 DVR DTV Receiver /...
The tv turns channel by it self
hello are you sure 1 of the channel button is not jammed in
shaun
Apr 08, 2009 | RCA R52WH73 Projection Television
Scrambled channels
ok mate ur not gonna get dem all bak on but ill be able to help ya get sum bak on ok well first type dese numbers in 00= bo b8 4f 04 e6 5f 87 80 and that shud give ya all tha channels ecept for movies and sky sports aswell
Apr 01, 2009 | StarTech.com StarView SV211K 2-port KVM...
No channel available
Unplug it for 10 secs and plug it back in then wait 10 more seconds and turn it on with the on/off switch. Unplugging makes it reload the firmware, but on/off does not. If that doesn't work try a factory reset. For my Panasonic you do this. Open front door to get at the buttons. Turn TV off. Press and hold the OK button and at the same time press and HOLD the on/off switch for about 3 secs. You should get a self check screen that will last a little while and then the TV will go to the menu screen.
Sep 06, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Televison & Video Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
