The tv will not come on no green light - was working before I moved it from my moms. hd50lpw62a model - it is all pluged in and connected to the cable wire. the remote is on tv mode. the remote to the tv not the comcast remote. - the on button does not light up no noise at all. not even any blinking light after we pluged in
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: RCA hd50lpw62a green power light
That set is famous for faulty flybacks. But its an easy inexspensive fix that takes under 30 mintues to do. You can get a new flyback at the following link for around 50 dollars and they provide free online tech support so you can do the repair yourself. You would need flyback number 259296 heres the link.
http://servicemanuals.vstore.ca/
Posted on May 15, 2008
SOURCE: constant blinking green power light but doesn't turn
This is from my WS65907 service manual.
4. Self Diagnostics
The “Power ON LED” provides an indication of the sets operation, and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
Pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is “24”, the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.5. Circuit Adjustment Mode
Most of the adjustments can only be performed using the remote hand unit. Many of the adjustments must
be performed in both the NTSC and HD modes. Video/Color adjustments must be performed in the NTSC
and HD modes, and data must be preset in the 480P (DVD) and VGA modes.
Posted on Apr 08, 2009
Bought new componant cables for new tv and the wii will not play in color. tryed moving cables around still no luck the different combo's that i tried either switched every thing to all red or all blue!...
Make sure the colors line up.
Red-Red
Green-Green
Blue-blue
If the tv has a second componant input then test it in that input.
What model tv are you pluging it into?
Did the wii work on the old cable?
Jan 03, 2011 | Nintendo Wii Console
Sub wont work
sub has to be on output not input
Jun 08, 2010 | Audio Players & Recorders
I have a rca hd50lpw62a and its slow to turn on and dim when on.
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.If you hear strange noises like buzzing or humming noises it could be the color wheel which is a little disc that has a gamma of colors and spins at high rpms.When the light of the lamp goes through it creates the colors on your tv.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.Your part # for the lamp is 265866 and you can find it here: http://www.discount-merchant.com/RCA-265866-265919-269343-271326-270414-Lamp-p/rca-lamp-265866-26591-269343-r.htm Good luck and blessing for your house!
Feb 10, 2010 | Televison & Video
The tv will not turn on anymore-have a blinking red light where the power green is located -is a flat screen hdtv connected to an xbox 360, tivo, and cable box. model no. 42PF9431D/37 . The cable is...
internal breaker, hopefully that xbox is plugged into a 3prong ac outlet. unplug the tv from electricity for a half hour and that circuit breaker inside should auto reset.
Dec 15, 2009 | Philips 42PF9431D/37 TV
Connected my monster cable component to my tv but no video worked last week tv is good could it be my playstation3 or the cable
Make sure you pluged the color coded cables up correctly, Green to green Blue to Blue and Red to Red. Sometimes in low lighting you can confuse the green cable with the Blue...
Oct 20, 2009 | Philips Magnavox 51MP392H Rear Projection...
Unable to switch my 15" LCD TV Receiver on
some tv sets dont come on when there is no picture signal in put, try and check your cables from the wall, aspecially connectors
Mar 24, 2009 | Televison & Video
Timer light flashes and tv wont turn on
The problem is the DM isnt completeing the boot sequence due to the failed caps. You can get the V21/V19 DM repair kit at the following link which contains the replacement capacitors and a CD with step by step instructions with pictures on how to do the repair. Heres the link.
Nov 14, 2008 | Mitsubishi WS-55511 55" Rear Projection...
RCA hd50lpw62a green power light comes on blinks and goes off tv never comes on.
May 15, 2008 | RCA Televison & Video
Black pic on tv turns green
normally this means the high voltage preamp green control transistor on the neck of the tube circuit board is loose solder connection from heat or is going bad.
Feb 17, 2008 | Sanyo HT32744 32" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
