Question about Husqvarna Garden
I am trying to find the owners manual for a yth180
  • 389 Answers
Obviously you haven't looked very hard for it yet.
A simple Google search for "Husqvarna yth 180 manual" returns thousands of sites, the very first of which has 10 or 15 different PDF downloads for manuals for this tractor:
lawnandgarden.manualsonline.com/manuals/mfg/husqvarna/yth180.html
Posted on Oct 09, 2009
I need a fuel pump for a Husq yth180 model lawn tractor. Where can I get one?
looks like sort of pump fits lots of models
plenty for sale on line
mower repair shops should have them or can get them
best take the old pump in as a sample
Amazon com N2 H727 Fuel Pump for all John Deere Craftsman Cub Cadet...
Oct 15, 2016 | Video Game Consoles & Games
My tractor will not start, battery is good; I think I need a solenoid or starter for Model # YTH180 HUSQVARNA Lawn, Tractor
Hi there I had the same problem with my rideon mower I thought it was the solenoid as battery was new but I found that the 1 of the leads that go to the battery had worn onto the chasey making it not to start put some electrical tape if worn or replace the lead.
Oct 29, 2014 | Garden
My Husqvarna yth180 Hydostatic turns over but will not start.
did the coil die?is it getting spark?is it a fuel problem have you tried starting fluid? did you run out of fuel sounds silly but i've see it
May 19, 2012 | Garden
Have a Husky yth180 mower. Battery was going bad and wouldn't start so I jumped it to finish mowing. Replaced battery and still won't turnover. Jumped starter and does turnover. All switches...
hi there dolson894
here is web site for owners manual
http://lawnandgarden.manualsonline.com/manuals/mfg/husqvarna/yth180.html
download owners yth180 manual it has a wiring diagram in it - may help
sounds like a starter solenoid problem, check for good grounding of the negative bat cable and grounding of the solenoid to the frame , check for 12 volt at the solenoid tab ( not the heavy contacts)
this wire solenoid tab wire comes from the S marked terminal from the main switch and power from the battery is taken from the HOT post of the starter solenoid up to the B terminal of the main switch, from there when contact made between B + L + S @ SWITCH voltage sent to solenoid for start
basic connections for switch in start mode is B + L + S
run / light B + L and Makes A + Y
run B + L off G+ M +L
check seat switch and brake switch - bypass with jump wire if need
across white to wjite wires on brake switch
see what hapens , the try a jump wire across the seat switch wires green to green and retry
if stil no good - replace solenoid as you mentioned with a jump cable straight on start motor turns over good
check out website
cheers hope it helps pauly46
dont forget the thumbs rating
Jun 07, 2011 | Husqvarna Garden
I own a Husqvarna...Model YTH180....I am looking for a new or good used deck.Will any other brand deck work on this mower?Do you have any suggestions on where I might find one? Thanks
there are mower boneyards around, you just have to look. try a google search in your state. also try ebay and craigslist. my yth 2148 looks just like my neighbor's craftsman, but the decks will not interchange.
Jul 01, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My electric PTO on my Husqvarna Model YTH180 does not engage
I'm having same problem. I think it's the switch, Running the system reads 14.6 volts. pull the switch No power to the lead that goes to PTO. if I jump 12v to the clutch the PTO engages fine. also changed the relay. Just wondering if there may be some other safety switch I may be missing? Hopefully it's just the switch. I dont know the likelyhood of those going bad the mower has tractor has 500 hours on it and looks damn near new.
May 31, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
We have a Husqvarna Rider, model YTH180. It's
whats rough the motor if so you could have bad gas or bad plugs or somethin els you may need to get that to a shop
Sep 27, 2009 | Husqvarna Garden
Husqvarna YTH180 rider, wont go into gear.
Make sure that the tranny has fluid in it. Then try rocking the mower back and forth until you rock the tranny loose.
Best regards, --W/D--
Aug 08, 2009 | Husqvarna Garden
Husqvarna YTH180 runs but won't go into gear
Check the drive belt. If it looks good and turns the pulley on the trans you will need to have the trans looked at.
Sam
Jul 12, 2009 | Husqvarna Garden
Husqvarna yth180
check the seat switch
Jun 09, 2009 | Husqvarna Garden
Garden Logo
252 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
