Question about LG RE-44SZ21RD 44" Analog Television
I have an LG RE-44SZ21RD, turns off after 5 minutes of use
I have an LG RE-44SZ21RD, it had a new ballast board on staurday, now two days later the tv randomly shuts down/ after only 5 mins didnt do that before the ballast board went, the lamp was inspected and its fine, any help please?
It might be worth checking that you haven't accidently activated the tv's sleep timer, I did on my LG DLP !!. always check the obvious first.
Posted on May 17, 2010
LG plasma TV 50PC5D. Have to push the power button for over 12 times, especially if not used for a day. If just watched and turn off and turn on a minute later, the TV can be turned on with 1 click.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 31, 2016 | LG Televison & Video
Flatron w1934s display problems; symptoms are black screen after 2 sec's of power up. i have tried wiggling the monitor cable/nothing, did notice if i unplugged the monitor cable you can see the screen...
hi good day
before you come up that the main board was the problem lets verify first to narrow down where the problem came from. now as you said you have been tried to put a backlight just to know if their is a problem with the backlight but still you have black screen so which mean the inverter ballast is possibly good as will as the backlight. ok here is on how will you trace the main cause you need to turn on the tv unit then check if their is a INV_ON voltage around 3.3V coming from processor going to inverter ballast, now if do not have voltage turn off the unit then disconnect the connector going to the ballast board and turn on the unit check again the INV_ON if still no voltage come out you have bad processor from the main board. now if the case is the INV_ON voltage is present their is a shorted component at the ballast board that is why the screen is going black after you turn on. if their is an error detected the main board will cut off. hope this will help you thanks for consulting through fixya god bless.
Sep 05, 2011 | LG Televison & Video
Kf-50xbr800 turns off for about 30 seconds, standby lights blinks 34 times before coming back on. stays on for 2 minutes then repeats cycle...
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
Aug 22, 2011 | Sony Grand WEGA KF50XBR800 50" Rear...
Set turns on then turns off a few seconds later
Set have the tv projection lamp problems.Tv have a "LAMP"LED light indication on the tv front screen panel are flashing are staying on lite?Yes,than the tv projection lamp life are ending.Tv have been on and used like 4 or 5 hours a day and the tv projection lamp been on the tv like a 1 1/2 or 2 years?If it is a new tv projection lamp,than ur tv might have a problem with a board call a Ballast board.This Ballast board job are to help to ignite the tv projection lamp.
Dec 06, 2010 | JVC HD-61FH96 61" Rear Projection HDTV
My TV screen went black and now the bottom light that is usually green, now blinks red 5 times in a row. Can you please tell me what is wrong w/ it?
5 times red standby light blinking shows problem with ballast supply board in Sony KDF-E50A10 model tv, ballast supply board provides high voltage to lamp to produce high bright light.
Please check/ replace ballast supply board in tv by local tv repairman.
Thanks.
Nov 07, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
LG RE-44SZ21RD 44
This is vcaused by a relay similar to a fluro/ neon light starter switch. This part has failed so it cannot get syncronization You will neede to have a serviceman replace this part.
Please rate our help to keep the free service online
Aug 26, 2009 | LG RE-44SZ21RD 44" Analog Television
I HAVE LG PROJECTION TV MODEL 52SZ30 REPLACED PROJECTION KAMP RESET LIFE TIME OF LAMP .BUT TV GOES TO STANDBY AFTER ONE MINUTE OF OPERATION CAN ANY ONE HELP PLEASE
Normally when this happens, this is because of the power supply board is going threw some abnormal fluctuation. i would check this board for minor solder breakage.
Feb 06, 2009 | LG RE-44SZ21RD 44" Analog Television
LG RE-44SZ21RD 44 whihc doesn't start
i think you'll find the lamp needs replacing
May 15, 2008 | LG RE-44SZ21RD 44" Analog Television
Open Questions:
See all LG RE-44SZ21RD 44" Analog Television Questions
LG RE-44SZ21RD 44" Analog Television Logo
586 people viewed this question
Computer Repairing
Computer Repairing
