Question about eMachines T3406 PC Desktop
The power button no longer works. IS the
The power button no longer works. Is the replacement of a power button possible? I have tried holding the power button in for a few seconds to see if it can make contact and nothing is working. I can see a green light inside the tower so there is power to the unit, I just can't get it to boot up. I have tried a different power cord and other things plugged into the power strip work fine. Thanks for any guidance you can offer.
    Problem Solver:
  • 18 Answers
I think your power supply has blown, take it to a computer store and ask them to replace the power supply then your problems should be over but you could just ask them to transfer computer box and that should also fix your problem because most boxes have a power supply in them. a small test you can do before that is get a switch open the pc and connect it to the mother board (without soldering it) if it turns on it is the switch then you buy a box if it doesn't make sure you dont use a toggle switch if you use a small hold switch and it wont turn on get a new box.
Posted on Oct 06, 2009
    Problem Solver:
  • 5 Answers
Probably the power supply. See if you can borrow a friend's power supply (not Dell) and temporarily replace the one in your computer with the borrowed one.
Start/cancel buttons no longer work
Dear Sir:
see this possible causes:
Power from the house
see for a blown fuse or c.breaker reset.
Door switch
this is important test it.
Wiring
loose or breake wires
Timer or selector switch
can be defective.
see the w. diagram for HELP. attached.
Now see if the starting relais is closed,because if are OPEN the machine will not work. Test it.
May 05, 2012 | Maytag MDB7609AWS Builtin Dishwasher
I have a Sharp LC-42D62U AQUOS TV. As a result of my grandchildren pushing buttons, inputs 1 and 2 are no longer available. We have followed every proceure in the operation manual to correct the problem to...
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Jul 27, 2008 | Televison & Video
Laptop wont boot up
Hello,You must not have anythinghooked up to the computer not a printer telephone cord for modem nothing.
You must remove the battery and the poweradapter.
You hold the power button down for two minutesto purge out the residual memory and power.
Then you plug only the power adaper in and tryto boot up.Sometimes you have to hold the power button down a little longer toget it to boot.
If it does not boot then try unplugging the cordand hold it down another two minutes.
Try again with just the battery.
If neither work you may have a bad battery aswell as power cord or possibly just a bad power cord that is not charging thebattery.
Pleaselet me know if you have any further questions or concerns.Alsoplease rate it if you like the answer it helps alot.Thanks.
Apr 19, 2012 | Toshiba Computers & Internet
I forgot the main boot password for my IBM 8172- how can I reset it? What if I dont have the setup disk?
You can try a couple of things. Unplug the machine, push in and hold the power on button for 30seconds or longer, plug back in and reboot, see if you can back into boot config. If not, power off, unplug, open case, remove the small LI-ION battery, its the round one in the middle of you MOBO. Press and hold power button like before. Replace, re-plug, re-try. Hope this works...cross your fingers.
May 22, 2011 | Computers & Internet
MY UPS IAM CONECT TO POWER. BUT IS NOT START AND POWER LIGHT ON SHOT TIME AND CONTINIVE BEEP SOUND AFTER IT CHANGE OFF.
I'm not sure but it is worth a try. Hold the power button down until the unit starts to work stably. I have tried this and it has worked before. Also make sure your printer is not attached to the battery back up.
Only your monitor and CPU should be on the Battery Back up Section. All other accessories should be on the other outlets. I have tried holding the button down on a friends, and it worked for a longer period.
It may need a new battery, or to be replaced because of the faulty switch.
Hope this helps you.
Best,
Mark
Dec 28, 2010 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
My Acer One notebook won't operate on electric power or charge the battery. I recall reading an on-line article about holding down the power button for 45 seconds and that worked once or twice, but it no...
Try this first, Unplug the power cord, remove the battery, Hold down the power button for 30 seconds, reinstall the battery, try to power it on, If it doesn't try to power on, The battery needs replaced, plug the power cord back in and power it on, If it still won't power up, then it's the power supply.
Nov 29, 2010 | Acer Aspire One PC Notebook
The child lock has been switched on via the tv buttons, but the remote no longer works. How do we switch off the child lock? It's a Telefunken 68cm Colour Television Model TTV-29NO2 - approximately 5yrs...
You can try pressing channel up & down buttons at the same time, holding for a few seconds,
Or unplug the set for a few hours. While it is unplugged, press and hold the power button for 5 long full seconds. Then wait half hour more and plug back in to see if it resets itself.
You can also buy an original replacement remote on many websites.
Feb 18, 2010 | Televison & Video
Our dishwasher's lock indicator won't turn off, even after holding down the heated dry button for 3 seconds. We also tried disconnecting the power for 5 minutes and it would not reset. What part do I...
Try holding the button down for longer say 5 seconds. When you push the button and hold it the little green light should blink. I would disconnect the power for longer..try 20 minutes. If that does not work then remove the inner panel and disconnect the control panel connector from the control box then plug it back in...see if that clears the locked control. If it continues to have a problem then you may need to replace the control panel.
Sep 27, 2009 | Maytag Dishwashers
PC on button flashes orange when trying to turn PC on.
Have you installed any new hardware recently? If so you may be reaching the limitations of your PS (power supply), or the supply may becoming old. One day when the button no longer works you will need to replace the Power Supply (or the button?). If you need assistance when doing this I can offer walkthrough help at http://www.hoosierpcrepair.com
thx
Jun 21, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Control locked onHe3
try unplugging then hold power button down for 10 secs or so with power removed this may help reset the control bd may even try holding lock button down longer than 3 secs i usually hold until light goes out
Jun 25, 2008 | Kenmore Elite 45986 Front Load Washer
eMachines T3406  PC Desktop Logo
232 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
