Question about Mitsubishi WS-55859 55" Rear Projection Television
My ws-55859 plays for 5min then high voltage shuts off changed the conv. ic already is it caps?
SOURCE: Mitsubishi HDTV 1080 WS-55859. Error Code 12
Did you push in the device and the menu buttons at the same time and get the error code...  I have the same problem and I get a 1,2 code....   I am looking for what the codes stand for...
Have you got any help on this....
Scott
mu email is smartin38@verizon.net
Posted on Oct 09, 2008
frcs68
  • 1605 Answers
SOURCE: Mitsubishi ws-55859 parts
time to get a new one.
even you get the main board, you might have other problem that has not show up yet.
Posted on Oct 14, 2008
  • 298 Answers
SOURCE: Mod. WS-655111 Fuse F9A04 & 05 bad. Set goes on & right off
You can order a replacement STK393-110 for this model (62HM95) from a major parts distributor at the link below:
Mitsubishi WS-65511 Replacement Part Convergence IC STK393-110
You would probably have to recalibrate the convergence after you install the IC. There may be a convergence kit available as well.
Posted on Apr 10, 2009
SD Tech
  • 14553 Answers
SOURCE: mitsubishi model ws-55859 tv is red and red
If it is WS-55859 and you go into the customer menu and find red or blue are skewed and will not adjust---you have a convergence problem.
This model uses a single STK-393-110 convergence chip--it and any of the protect resistors around it that are bad will need to be replaced and the set adjusted.
The chip can be purchased on Ebay for about 12 dollars plus shipping--total parts cost should be under 30 dollars!
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS MODEL.
They tell you everything you will need and how to do the repair---If you or someone you know can do it I can post or get the instructions to you.
If you cannot do it shop around your area--most shops are going to get 300 or MORE for this kind of repair and many will not do in in your home--Any good tech can do it in your home in about 1 hour--I know as I have done hundreds of them.
If you have questions or need help let me know--I am here to help people.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 11, 2009
SD Tech
  • 14553 Answers
SOURCE: Mitsu WS-55859---turned off & only powers up for 2 secs
2,2 is short protection.
98% chance the fuse or fuses (there are two 5 amp pico fuses) that protect the convergence circuit are blown. If you find F9AO4 OR F9AO5 on that board check them--if either is open the STK-393-110 DID IT.
Fairly short life for this chip if it was installed correctly and had heat sink compound applied to it--once in a while you get a bad one.
If this has helped you, rate this solution as I do this here for FREE.
sd tech
Posted on Nov 19, 2009
My mitsubishi TV ws-55859 does not turn on. The green timer light comes on and goes off after 3-4 seconds but tv does not turn on. What could be the problem? Help please......
Poor solder connection and Bad STK ICs 2 of them replace Both Big Black IC will have part number on them Call Mats for STK 1-800-628-1118 example
STK392-570.
Nov 18, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Apr 10, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65908 Error Code 24
If you have an ohm meter, check the resistance from F9A04 to ground, and then reverse the leads and check F9A05 to ground. These supply +24 and -24 to the convergence integrated circuits. The conv ic's may be bad. Also, code 24 usually indicates vertical deflection failure as well. One other check to make.....The pic tubes on this set may leak a few drops of coolant onto the boards. Look VERY carefully for liquid drops on the boards or a green and or white corrosion spot or two on the boards under the pic tubes-near the front of the chassis.
Dec 12, 2008 | Mitsubishi WS-65908 TV
Mitsubishi ws-55859 projection tv with 2-3 error code
did you change the two pico fuses F9A04 and F9A05 when you replaced the Convergence ICs
Sep 25, 2008 | Televison & Video
Scott
Sep 11, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Have mitsubishi with same problem blinking light
try unloading convergence yokes and and turn tv on if turn on your problem convergence IC's
Apr 01, 2008 | Mitsubishi WS-55859 55" Rear Projection...
WS-55859 Won't Turn On
this is a job for experienced tech most of the problems are rela ted to convergence IC's in this case
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Wont turn on
work around convergence check voltage to convergence IC's if is ok, I' had same problem. find out one of the ic's was shorted
Tv wont turn on
ok is in shut down mode kine of proteccion some of the fuses are pico fuses but you may have problem with convergence IC's that what I' check first if that is ok go to HVT .. if U still have problems e-mail me
Mitsubishi WS-55859 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
