Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
The motor is running, but the unit is not spinning
    Problem Solver:
  • 9 Answers
Almost always, the clutch "fingers" are stuck because of rust / yard debris... dissasemble the housing and lean the clucth , reassemble
Posted on Oct 10, 2009
  • 279 Answers
Drive shaft either broken or there is a clutch. You might also look at the head to see if there is something loose there. Good luck...Lee
Posted on Oct 06, 2009
My Inglis by Whirlpool washer doesnt spin. Its a Direct drive unit so Im guessing that the clutch is bad?
does the motor run when its supposed to spin? if not its probebly a lid swich problem. if the motor runs it may be a coupler or poss. cluch. sometimes a sock in between the tubs.
May 07, 2014 | Whirlpool Inglis IP4400 Washer
Tub doesn't spin during spin cycle; motor is running
does the unit agitate?
is it does and it will not spin then the transmission is bad.
if the unit does not spin or agitate then check the belt.all assuming that the motor is running.
Mar 14, 2010 | Westinghouse WWS833ES Super Capacity Top...
Interior cooling fan has stopped spinning,
No fuse. The obvious thing is to check the motor itself, which means it must be pulled. Once you gain access to the motor, with the power shut off to the unit, try spinning the blade to see if it is bound up.
If it's spinning freely, remove it from the unit, and test the windings on the motor for continuity with a VOM meter. If you have no meter or access to one, or aren't familiar with electrical, then take the motor to an Appliance parts house. They can usually test it and most carry motors that are adaptable for beverage coolers. Make sure they know whether the machine is a 120 or 240 volt unit.
If I'm not mistaken that motor runs 24/7 when cooler is powered up.
Oct 29, 2009 | Carrier Beverage Air® Marketeer® MT12-1-B...
After about 5 minutes the unit stops working. No sound or even a fan noise. I just cleaned the filter to see if that helps, but it didn't.
Is the fan running and stopping before the unit completely quits?
If the fan quits the compressor won't run very long.
I would start with the fan motor or capacitor.
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
r.
Aug 21, 2009 | Dehumidifiers
Will not run - compressor runs
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 14, 2009 | LG DH30 GoldStar Dehumidifier
Motor will not start, if I spin the blades it will run
if the motor starts when you spin it find the capictor and replace it
Aug 10, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Fan on unit not running
Aug 09, 2009 | Heating & Cooling
A/c unit runs but only blows into the house for about 30 seconds
Jul 28, 2009 | Goodman GMS90703BXA Heater
Condencer unit fan wont run
If you have power to the fan and the fan won't come on, then its bad. You don't have to do another check. You will know if the capacitor is bad by turning the power on to the unit and taking a stick to start the fan. If the fan starts running after manually spinning, then the cap is bad. If not, the motor is bad.
Apr 02, 2009 | Heating & Cooling
Won't agitate or spin
If you mean that when the unit should be agitating or spinning the motor is running, and you lift the lid causing the motor to stop running, it sounds like the coupler.
Mar 31, 2009 | Whirlpool LSR5132PQ Top Load Washer
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
259 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
