Question about Lands Phones
AVAYA PARTNER ACS PHONE SYSTEM
We have an AVAYA PARTNER ACS PHONE SYSTEM model with 6 phone lines. Currently if somebody calls after hours on the main line they receive an automated greeting and then the caller can transfer to an extension. Going forward, we would like all calls on two of the lines (5 & 6) routed to a separate automated greeting or a indiviual voicemail box extension instead since there are two separate business entities under the same roof. Can this be programmed?
    President:
  • 860 Answers
Yes it can. Depending on the type of voice mail attached to your system you can both have the lines answered with a seperate main greeting (partner messaging can do this) or answered by a seperate mailbox (all partner voice mails).
Posted on Oct 06, 2009
Testimonial: "thx"
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
I have a partner mail VS R4.0 system. I am trying to have calls that come to my extension auto forward to an outside line like my cell phone.
What releas is the processor? You need an ACS, Release 6 or newer.
From any display phone, press Feature 59. That will tell you the release.
May 04, 2010 | Comdial Avaya Partner ACS Phone
Partner ACS turning on and off on it's own
One of the cards is bad in the unit. Assuming you have a 308 processor and 308 ec card and two cards in the system The 308 ec card has a bad or power supply in the card
When this happens look at the cards lights.
This is nothing you can fix yourself without a Avaya technician.
Apr 08, 2010 | Avaya Lucent Partner 616 Phone
Partner ACS phone system won't fwd calls to mailbox
If they want all calls to be answered by the general delivery mailbox only them you need to change the Group Distribution (#206) on all the lines in group 7 from (1) assigned to (3) VMS Line Cover and also change the Line Coverage Ext (208) on all lines to ext 10
Dec 18, 2009 | Comdial Avaya Partner ACS Phone
AVAYA PARTNER ACS PHONE SYSTEM - Separate Greeting
The partner voice messaging system would be a card that looks like the processor card , It should also have a green sticker on the face of it identifing it as such.
Dec 11, 2009 | Comdial Avaya Partner ACS Phone
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#206"
the display should say Group Call Distrib Group:
Press 7 It will then ask for a line number
enter in 05
the display will say 1 assigned
press 3 VMS Line Cover
Do the same procedure (from #206 on) for line 6
Then enter #208
The display will say Line Coverage Ext Line:
Enter 05 The display will then say Data --
Enter in the extension you want the voice mail to pick up the lines on
Lastly if its not done allready, enter #301
The display will say Automatic VMS Cover Extension:
Enter in the extension number of the phone thats getting the voice mails
The display should say 1 Assigned
press feature "00" to logout
Oct 06, 2009 | Lands Phones
AVAYA PARTNER ACS PHONE SYSTEM - Voicemail/Greeting capability
Yes you can have the 2 lines answered by a particular mailbox instead of the AA greeting.
Would need to know the model of the voicemail system that is installed to see if there are more than 1 AA menus.
Oct 06, 2009 | Avaya Lands Phones
Lucent Partner 34D phone system with 18D extensions
That doesn't sound good at all. I would first try powering down the system and waiting about 15 seconds or so before powering back up. If the problem remains, the processor was some how damagedand would be best if it was looked at by your vendor.
Sep 25, 2009 | Avaya Lucent Partner 616 Phone
Avaya Partner ACS & 18D - Call Waiting Not Working
It's easier and more stable to program a button for FLASH (F03). The timing is in program 107 and sets to about 18-20 for 450 to 500 milliseconds.
Carl
Jan 26, 2009 | Avaya Corded Phone avaparp18d
Changing announcement on Avaya Partner ACS phone
Selector code 3 is playing an announcement. You have to go into programming, press selector code 3. depending on the voiceail yu have....you may be able to modify it right there.. Other wise you willl have to find the annuoncements.
If you repost with what voicemail model it is, i can tell you exactly.
Feb 18, 2008 | Avaya 700340193 Corded Phone
Lands Phones Logo
255 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
