I have a Sony Trinitron KV-32HS510 Television. When I try to turn it on, the standby red light blinks 7 times. It sounds like the television turns on, but it doesn't. The light just blinks over and over. Should I call for a repair - can I repair this myself - ?? Thank you.
  • rmhendry Oct 07, 2009
    Actually, when I posted previously, it was my wife that told me it was blinking 7 times. I'm looking at it right now, and it's blinking 6 times. Let me know what you think. If this is also a repair, can you give me a ballpark figure on how much the repair would be... Again, if this is not something I can do myself.. Thanks.
  • 788 Answers
I have reviewed your problem and have found that
You Have a bad lamp driver board or a bad lamp.
If when you turn the unit on, the light turns green and then red and flashes 6 times.?
This kind of repair should not go over $200.00 if both the Lamp and board need replacement.
A lamp replacement in house, $120.00
Hope this has help you.
Posted on Oct 07, 2009
  • 10,594 Answers
7 times blinking LED in Sony KV-32HS510 shows error of Horizontal Deflection is Stopped in TV and of course it is qualified tv tech job to fix it because it requires troubleshooting, voltage and components testing in horizontal deflection circuitry. It is not user level repair like replacement of fuse etc.
I would recommend to call tv tech for fix.
Thanks.
Posted on Oct 06, 2009
What is the life span for the Sony Wega KV-32HS510?
10,000 continous woking hours is calculated to most of the CRT based TVs.
It is only calculation, but the life span might be much more that that. I've repaired a Sony TV recently, which was released by Sony Corporation Japan. The model is KV1820, an 18" Trinitron TV, still works perfectly. Just see, it is an '80 model one.
Jul 31, 2014 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Turn on my Sony FD Trinitron WEGA KV-32HS510 32" TV, you hear a click, and then it blinks 3 times pauses and repeats.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. This is the fault with 3 blinks. If you wish to get more, check the site linked here.http://electronicshelponline.blogspot.com/ Pull up previous posts, either by brand search, or view it in Mosaic / Timeslide / Flipcard option.
Aug 18, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Problem with Sony FD Trinitron WEGA KV-32HS510 32" TV
Blinking of standby LEDs to Sony TVs are fault indications. Form the number of blinks occur at one time, the repairman can get an idea of the faulty stage inside it. According to you, it blinks 4,6 & 7. Just visit this site, It has details about blinking codes to Sony TVs, both CRT based, Flat panels and Plasmas. I can't provide more advice to you, because the number of blinks are not constant. Check the site, and get it.
Jan 22, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
My tv want turn on and the standby light just blinks 7 times
Do a google search for SONY LED BLINKS and select the second choice in the list. This is a known problem with these tv's it will require the two 18 pin IC's replaced on the D power board.
Good luck
Rich
Jun 06, 2010 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Blinking Sony Trinitron with no picture or sound
you have a drive ic problem. ic 600, r640 and modification needs to be performed. Take to a Sony servicer. Est.$150 parts and labor
Dec 30, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV will not come on.
The 7 blinks indicate a high voltage shutdown (high voltage exceeded 33,000V). This is usually caused by a defective regulator. Could you please post the exact model number (KVxxx) and I'll look up the part you will likely need?
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
The 7 blinks indicate an over voltage condition. The high voltage section has exceeded 33,000V. This is generally caused by a bad regulator. I don't have a listing for your model, but there should be a multi-pinned IC attachd to a heatsink marked STRxxx located close to where the AC cord comes into the set. Post the actual marking here and I'll get you the part number and cost. That is the regulator that may be the problem.
Dan
Jul 15, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
