Question about Frigidaire Washing Machines
Frigidaire Affinity front loading washer 7000 Final Spin
Frigidaire front loading washer 7000 Final Spin Cycle gets stuck at 1 minute. No error codes displayed--just spins, slows down, spins, etc etc. Must depress cancel button to stop the machine.
  • rebesal Oct 07, 2009
    This is a FRONT LOADING machine. I have the service manual, and cannot locatre the safety switch you mention. Further ideas? Thanks.
    Washer runs full cycle, and when final spin ought to stop, still shows "1" minute in window. spin cycle slows down, then seems to try to drain again, and keeps going back to spin mode.
    I had the machine open two days ago to clean the coin catcher in the drain (it had ingested two of those all in one soap / conditioner pads.
    Could I have done something in making that repair? Any idea what board controls spin cycle? is there any mechanical interconnect other than the door lock which ALLOWS it to spin?
  • 986 Answers
It sounds like your timer has gone out. Repair of the timer should fix your problem.
Posted on Oct 07, 2009
    Brigadier General:
  • 3,513 Answers
Hi
The reason for this Could be the safety switch which is faulty which is activated by closing the lid. There is a plastic section on the left hand side of the lid which activates the switch. The plastic lip sometime breaks so you need to rivet a piece of alumimium in place.
Thanks for contacting Fixya.com
Posted on Oct 06, 2009
    President:
  • 1,884 Answers
IC controlling the spin operation seems to have gone faulty. Or about to go.
WHY DO I GET ERROR E47 WHEN THE SPIN CYCLE IS SUPPOSED TO START?
Good Afternoon Friend,
I understand you are receiving an E47 when the spin cycle is supposed to start, on your Frigidaire Affinity washer, model# ATF7000E. The E47 code states that the control board of you appliance thinks that the door is open. This could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Once power is restored, start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Affinity ATF7000E Front Load...
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
Does not empty after final spin cycle I have checked the pump and hoses. The only thing I see may not be right a cylinder shape is in the boot at the outlet.
Hi Peter,
So I see that your Frigidaire Affinity washer is not draining completely after the final spin. I also see that you've checked the pump and hoses as well. There are a couple of other troubleshooting tips I might suggest.
1) Make sure the standpipe isn't too tall. Maximum standpipe height should be 8' (2.4 m).
2) Check the house drain pipes to see if they are clogged. If so, unclog the drain pipes. Contact plumber if necessary.
-Best Regards-
Jan 23, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire affinity error code 12
Clear code, exit mode and start dryer. If problem persists, replace Main Control Board
Aug 17, 2012 | Frigidaire Affinity ATF7000E Front Load...
back tub bearing,,and spin surport,,defective,,,under warranty,,,call for service..onthejob
Dec 10, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF6000ES Error code E-48
you might have some thing in the pump check pump first if Therese nout in there then it might be your brashers you will have to look on ebay and don't for get to wright your model number down there really cheap if you get stuck get back to me i will help
Dec 15, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
