Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Unit is acting eratic giving an F2 code on display then "pan" on display. Walked in from work and unit was running on its own. Opened door and got display messages.
I'm having the exact problem!! Help!
Posted on Oct 27, 2009
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
We have an Amana AMC6138AAS microwave/convection oven. I was cooking popcorn last night and opened the door before the timer stopped. When I opened the door the inside light and the control panel went...
Did you have a power failure? Could be an overheat situation. Try unplugging the unit, wait 30 seconds and plug it in again. This resets the unit as long as there isn't a breaker or fuse blown. If it is a power issue, the display should start flashing. Did you get any error codes?
Dec 20, 2017 | Amana Microwave Ovens
My GE JE1640GB MW kept running after I was done using it. I held down the Off button to try and reset it, which locked the unit (unit reads "Lock" and diplays an L when running). I need to...
Thank you so much for the info. The WD 40 worked perfectly on the door and my microwave in not turning on every time the door is opened. This info saved me time and $. Thanks
Dec 01, 2010 | GE JE1640 Microwave Oven
I have a one touch microwave & have misplaced the manual. The code F2 keeps coming up on the display. What does this mean?
F2 on a Whirlpool microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Please reply back with your full model number from the tag in or on the unit so we can help you with an estimate or free DIY tips.
Sep 06, 2010 | Whirlpool Microwave Ovens
Microwaves
I can help solve this fiasco , opening the unit while its running to stop it is not good to do because it will wear the door switches due to the load of power the unit uses while running the switches are not made to cycle the unit.
2nd there is radiation in the unit and around the unit while running so you should not reach in inside the unit immediately when stopped , give it a few seconds. Some commercial microwaves have an un-safe level of radiation 20+ feet away from the unit.
Most likely why they always get the order wrong.
Hope this helps.
Phil
Jan 07, 2009 | LG LRMM1430 Microwave Oven
Microwave stopped working
Yes, there should be a ceramic (tubular) fuse under the cover on the top side where the power comes into the microwave.
Dec 11, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
The unit loses power.
check control circuit may be dry solder at conrol circuit, check door switches also , check all wiring connectors and circuit.
Nov 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
277 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
