Question about Ruud Handler Air Conditioner
Heater doesn't work
I have the round digital honeywell thermostat. Usually I switch the little knob to "heat" and the other one to "fan" and press the up button to increase to desired heat, the hot air comes out. Yesterday, I did the same thing and it isn't working anymore. I just feel the cold air coming out of the vent. I've been messing around the set button but still nothing. Please help.
  • 98 Answers
How old, at a guess, would the thermostat be?
This will help in figuring out what might be wrong.
Posted on Dec 23, 2007
The thermostat works fine for heat, but as soon as I switch it to cool, the air conditioning will kick is but the inside thermostat will not change, causing the air conditioner to run continuously
If the temperature doesn't drop when the air conditioning is running for some time (two hours), the air conditioner is not working. The problem is not in the thermostat.
Jun 14, 2011 | Honeywell CT500 Digital Heat / Cool Manual...
How do i change an old style honeywell room stat
Shut the furnace off for starters. Remove the old Thermostat. As you remove each wire write down what terminal it wen to.
Red wire usually goes to R-Power
Green Wire usually goes to G-Fan
White usually goes to W-Heat
Blue or Yellow usually goes to Y-Cool
Jan 04, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Model # RTH 1108 stopped displaying the
is my thermostat( honeywell rth1108) somehow to my attic fan. cant find a off switch for the fan. seems it is controlled by the thermostat.
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
Replaced mercury thermostat w/Honeywell CT87K - doesn't work!
You need a specific thermostat for a Wall Furnace it is a Millivolt Thermostat and not a 24v standard thermostat....usually it will work anyway however if the powerpile (generator produces millivolts from the pilot light) is weak it may not be producing enough...or the Pilot light may be dirty and lazy...won't produce enough millivolts ...or you can have bad or dirty contacts or connections....or a combination of any of the above.....a 24v Thermostat and particularly a non-mercury thermostat has too much resistance in it for a millivolt your Wall Furnace (other than the fan) runs on less than 1 volt
Oct 31, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Honeywell T86A3006 24V Class 2 Round thermostat 8020
The honeywell tradeline thermostat would work as a direct replacement (no mercury in the new ones), however if your using just heaters and no cooling system off of it, you could Heat only thermostat from honeywell that would replace your unit as well. Both at available at Ace Hardware with the heat only unity being roughly 7 dollars cheaper.
Jan 14, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell Surround HZ2200 / HZ2204 /
A link to an Adobe (Acrobat) Reader format (.pdf) owner's manual for Honeywell® (Mini Tower) SURROUND HEAT™ HEATER FAN Models HZ-2200 (charcoal) and HZ-2204 (white) is here.
Some text from the manual:
• The Surround Heat™ Heater is designed to
disperse heat in either a 360° range or in one direction only.
• To select the desired heating mode, slide the Direction Control switch, located
on the top of the heater, to the position of your choice:
– to the right (full circle) for 360° Heating
– to the left (half circle) for forward only heating (One Direction
Select the appropriate heat dispersion mode. (See
Set-Up instructions.)
• With the Power knob in the OFF position, plug the
heater into a polarized 120V outlet.
• Turn the Thermostat control fully clockwise to the
HIGH setting.
• Turn the heater on using the Child Resistant switch
(Power knob). To operate the switch, push down
the two sides of the Power knob while turning it
clockwise to the desired position. The power
light will illuminate. The Child Resistant switch helps
ensure that the heater can not be turned on accidentally.
• When the room reaches a comfortable temperature, slowly turn the Thermostat
control counter-clockwise until the heater goes off. This is the point at which the
Thermostat setting equals the room temperature. At this setting, the Thermostat
will automatically turn the heater on and off to maintain this selected temperature.
• Push down and turn the Power knob to OFF and unplug the heater when you
are finished using it.
Nov 04, 2007 | Honeywell Surround HZ2200 / HZ2204 /...
Honeywell digital thermostat won't turn off ac.
The Honeywell CT87 thermostat is a normal round thermostat, not digital and may have a sub-base installed with it that has a two switches on it. One is for Fan (Auto or On)and the other is for Heat, Cool and Off. Make sure the Fan switch is in the Auto position and the other switch is in either the Cool or Off mode. If you continue to get cooling, you have a short in the thermostat wire or a stuck relay in th indoor or outdoor unit. To test this, while the unit is running; remove the round outer ring on the thermostat by pulling it straight off towards you. You will find 3 slotted head screws that hold the thermostat to the sub-base. These screws are located at the 3 o'clock, 7 o'clock and 9 o'clock positions. Turn these screws counterclockwise with a small head screwdriver. They are held in place so should not fall and get lost. With the front of the thermostat removed from the base, the air conditioner should stop running. If the unit continues to run, you will need to have your A/C system inspected by a technician. If in fact your thermostat is digital, look to see how it is mounted to its sub-base and remove it. If the system stops, you may have a bad thermostat or the Fan switch is in the On position. Hopefully this will help.
Sep 11, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
85 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
