Question about Nania Airway LX
Have washed the covers and now can't get the shoulder seat belts to fit. Their too short.
Cant put the straps back in the correct way after washing car seat please help!~!!
Posted on Jan 24, 2010
How to remove a back seat from 02 toyota avensis
Hi, peel the cover from around the seat frame so that the shoulder strap hold the cover on to the seat.
Extend the set belts to their maximum length and recline the seat as far as possible.
Looking at the seat from the front, put your hand in the gap between the reat of the seat (bit that reclines) and the fromt of the fixed base (by the red dome and the instructions).
On the bit of the seat that reclines there is a 'door' that opens to reveal a metal clasp that the ends of the shoulder straps fix to at the top and the ****** belt at the bottom.
Unhook the looks from the shoulder straps from the metal clasp.
Pull the shoulder straps through the back of the seat upright. You can now pull them through the cover which is free for you to wash.
Thank you.
Jun 06, 2012 | Cars & Trucks
Infant car seat highlander2002
I am not familiar with the vehicle but car seats are not all made to fit any vehicle.
There are some that require just the lap belt most require an over the shoulder design. You will have to get the store to let you try a few in the vehicle until you find one that suits. I would expect a young child (baby) seat to require a 3 point over the shoulder style seat belt. especially if you are fitting the seat in the middle as this is the worst place in the event of a head on impact, unless you have full restraint. The other thing to remember is that children as they grow older may decide to take the shoulder straps off as you drive, making them more vulnerable. There are devices out there to help prevent this.
If your vehicle doesn't have a three point harness in the middle you should be able to get one fitted. Ask you Toyota dealer if there is an approved after market belt
Nov 17, 2011 | 2002 Toyota Highlander
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
How do you put the cover on the seat?
If it's the new model then you need to follow this in reverse order for Cleaning the Quinny Buzz seats (comfort cushion and XL seat)
1. Open safety harness
2. Unfasten the shoulder belt snap and hook and remove the belt pad.
3. Loosen all snaps on the bottom of the seat
4. Loosen the Velcro straps on the bottom of the seat. Remove the belt buckle through the opening of the seat
5. Slide the cord of the seats out of the edges of the Quinny Buzz seat. Start with the foot section and work towards the head section
6. Pull the lap belt of the Quinny Buzz seat through the holes of the seats and remove the loops from the shoulder belts from the openings of the seat
May 19, 2010 | Quinny Buzz 3 - Juice Travel System...
Removing seat cover maxi cosi priorifix
To be able to remove the seat cover from your seat you have to 'unhook' the seat belts at the back of the seat:
First extend the seat belt to the maximum length.
Then put the seat at the maximum recline.
At the back of the seat-'shell' you will then see a metal hook that hold the shoulder straps: unhook and pull forward.
Reassembly is just the reverse.
A few more tips when removing the cover from a PrioriFix: take care not to damage the white extruded foam when pulling the belts forward and when taking off the cover. When the foam is not protected by the padding it may easily snap.
The seat padding is cold wash only and no spin-dry, otherwise the seams may loosen.
Please don't hesitate to use the contact form at http://www.babycare.nl if you need any further assistance.
With kind regards,
Babycare.nl Sales Desk,
Erwin de Raad
Jun 21, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
How do we fix front passenger side seat belt retractor on 1999 Ford Taurus? It will not pull out....
you may have to remove the bolt that holds the buckle to the floor. Try to push the belt into the retractor and see if it frees up.
I assume you are saying it is in the locked mode. It has an automatic lock mode for holding a child seat. When the belt is pulled all the way out, it goes into locking mode. You will hear it ratchet when the belt starts going back in.
Section 01-20A: Restraints, Active 1999 Taurus, Sable Workshop Manual
DESCRIPTION AND OPERATION Safety Belt, Lap/Shoulder The dual locking mode retractor on the shoulder belt portion of the combination lap/shoulder safety belt for the front seat passenger and rear seat outboard passengers operates in two ways:
  1. In the vehicle sensitive (emergency locking) mode, the shoulder belt retractor will allow the occupant freedom of movement, locking tight only on hard braking, hard cornering or impacts of approximately 8 km/h (5 mph) or more. The front and rear outboard seat belt retractors can also be made to lock by pulling/jerking on the belt.
  1. In the automatic locking mode, the shoulder belt retractor will be automatically locked and remain locked when the combination lap/shoulder safety belt is buckled and does not allow the occupant freedom of movement. This mode provides tight lap/shoulder belt fit on the occupant and on a child safety seat or infant carrier installation restraint.
  1. When the combination lap/shoulder belt is unbuckled and allowed to retract completely, the retractor will switch to the vehicle sensitive (emergency) locking mode.
sxh~us~en~file=ani_caut.gif~gen~ref.gif WARNING: REAR-FACING INFANT SEATS SHOULD NEVER BE PLACED IN THE FRONT SEATS.
The automatic locking mode must be used when installing a child safety seat on the front passenger seat and rear outboard seats where dual locking retractors are provided
Apr 21, 2009 | 1999 Ford Taurus
Lost my Instructions for a Britax Asis Car seat
First attach the long belts to the bottom of the chair. Then feed them through the seat cover and replace the cover. Feed the belts through the back of the chair (through the required shoulder height) and attach to the metal harness at the back of the chair. The folded over edge goes on first, so make sure you put the right belt on the right side! Finally, feed the padded shoulder straps through the same hole as the long belts at the to of the chair and that's it!
Any more problems, drop me a line
Apr 11, 2009 | Baby Gear
Seat Belt repair/replace
  1. Remove front seat.
  2. Remove adjuster cover. A
  3. Slide floor anchor cover.
  4. Remove floor anchor bolt. B
  5. Remove shoulder anchor bolt. C
  6. Remove front and rear kicking plate, then remove center pillar upper and lower garnish.
  7. Disconnect seat belt pre-tensioner connector.
  8. Remove the screw securing seat belt pre-tensioner retractor, then remove seat belt and seat belt pre-tensioner retractor.
  9. Remove bolts securing seat belt adjuster, then remove seat belt adjuster. Reverse procedure to install.J
Nov 03, 2008 | 2000 Nissan Maxima
Electric retractable seat belt problem
check your fuses. there is also a lever next to te parking brake..make sure it's down
May 17, 2008 | 1988 Toyota Camry
How do i get the seat of to wash?
I was able to find an online instruction manual for this stroller. From that manual, I was able to find the following instructions for removing the seat for cleaning.
"10 REMOVING AND REFITTING THE SEAT COVER
Remove hood from stroller if fitted.
A Twist shoulder strap end buckles and feed through holes.
B Feed waist and crotch straps through holes.
C Unclip seat cover retaining straps.
D Unfasten seat fabric from handle tubes and seat base.
E Slide fabric from seat back and base.
F When refitting seat fabric, insert seat back support tubes
into fabric slits.
G When refitting seat fabric to seat base, loop fabric flap over legrest
strap and pass crotch strap buckle through both holes in seat fabric
and then hole in seat base.
H When refitting shoulder straps, twist buckles and feed through holes."
Dec 18, 2007 | Maclaren Quest Mod Stroller
Nania Airway LX Logo
478 people viewed this question
Top Nania Baby Gear Experts
Nikki  Mclean
Nikki Mclean
Dorel UK
Dorel UK
Are you a Nania Baby Gear Expert? Answer questions, earn points and help others
