Hello, yes it could be a relation betwin them to because the ignition system is related to the charging system. The switchcould be triggering the charging system You have the battery connected to the switch via a relay, in turns the battery is also connected with the alternator via a relay if not the same with the switch. So, there might be the issue specially if the alternator was working fine prior to the switch change. Please check the wiring from the switch to the battery and the wring from the alternator to the battery. If all is fine check if the alternator is charging the battery.
you have a earth problem/neg on battery check the battery wires i suspect a dirty connection.get that starter checked again and test the most common problem[ THE BATTERY].adrian,,,,
It is due to some kind of electrical contact failure. For more
details and common causes of Err 99 read the following article: http://www.lensrentals.com/news/2008.12.31/canon-err99
IF YOUR BATTERY IS FINE, YOU HAVE TO CHECK THE HARDWARE..
IF THE BATTERY IS NOT FINE,CHANGE YOUR BATTERY..
THIS BOTH PROBLEMS ONLY KEEPS YOUR PHONE IN OFF AND ON..
I HOPE,THIS SOLVES THE PROBLEM..
Help please....I have Mazda Protege 2002...the car was driving good..and suddenly the car didn't start at all i changed the starter the battery is fine because when i start the car the lights comes on and the radio works. I don't know what is the problem is...when i start the car it makes noise of tik tik. Please help me????
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
