Question about Kenmore Elite 45986 Front Load Washer
I am changing a 3 prong dryer cord to a 4 prong cord. I have green to green white to white red to red and black to black. Do I need a white to green jumper?
  • 87 Answers
SOURCE: kenmore ele dryer
Remove the ground strap from the middle terminal block in the dryer. Attach the white wire to this terminal. Take the green wire and attach it to the frame of the dryer. Attach the red wire to the right hand terminal, and the black wire to the left side terminal.
Posted on Jun 08, 2007
  • 135 Answers
SOURCE: kenmore dryer cord change
if you have the new plug the wiring is the same just without the green wire....just leave it off
Posted on Jun 24, 2008
  • 726 Answers
SOURCE: Kenmore Washer/Dryer Combo Unit Cord Issue
the extra prong is just anothere earth over here we hacve three prongs and 2 prongs its just a better earth thats all and it wontstart a fire ii always change mine i did it to my toaster,microwave,iron,and pc all over 1 yr ago nothing ever happened
Posted on Sep 15, 2008
  • 10865 Answers
SOURCE: i need help in changing the 4 prong to a 3 prong cord
It would be a better and safer idea to change the receptacle from a three prong to a four prong. You would also be in compliance with the electrical code. That being said, here is the info you will need to go either way.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Posted on Apr 04, 2009
SolutionGuy
  • 331 Answers
SOURCE: Kenmore Dryer model 86683100. I need to change
Yeah, red and black go to the outside terminals, white in the center and green goes to the cabinet. What I do is hook up the red, white and black, then I place the green between the terminal block cover and the frame and screw it in tight.
SG
Posted on Apr 05, 2009
How do I change a 4 prong to a 3 prong dryer code
When replacing a 4 prong cord with a 3 prong cord you put black and red wires to the outside posts of your terminal block. The white wire from your three prong dryer cord goes to the center of your terminal block. The yellow and green wire from the dryer go together and attach to the cabinet ground.
Nov 22, 2014 | Dryers
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
I HAVE AN OLDER MODEL KENMORE DRYER MODEL NUMBER 86872800 AND A NEWER HOME HOME WITH 4 CONNECTORS DRYER HAS ROOM FOR THREE HOW DO I CONNECT NEW CORD
You have to replace the dryer's 3-prong cord to 4-prong. Get yourself a 4-prong cord then on the terminal block at the rear of the dryer, connect the wires of the 4-prong cord to where the same wire colors (red, black, and white) of the 3-prong cord connects to. The only modification needs to be done is on the green/yellow stripe wire that connects from the white wire terminal to the dryer's cabinet. Remove this wire (green/yellow stripe) from the white wire terminal then connect it to the same wire color (green/yellow stripe) of the 4-prong cord and you are done. The new wire configuration would then be red, black, and white on the terminal block and green/yellow stripe wire on the cabinet.
Jun 16, 2011 | Dryers
Dryer cord
Your four prong cord has 4 wires. Black,Red,Green and White.
Remove the 3 prong cord from the dryer.
The Black and Red wires go to the outside terminals on the dryer. The White wire goes top the center terminal. The Green wire goes outside the terminal cover to any nearby screw for grounding.
Jan 03, 2010 | Roper REX4634KQ Electric Dryer
Changing electrical Cord from a 3 prong to a 4 prong. I need a wiring diagram
black to black lug white to white lug red to red lug green to ground(any bolt that is attached to body of dryer)
Dec 20, 2009 | Whirlpool Dryers
Dryer 4 tp 3 pring cord install
Hello wgirdler,
While it is preferred to upgrade the receptacle to a 4-prong type (which includes Neutral & Ground) Code requirements grandfather in 3-prong receptacles in older homes. So if your preference is to remove and replace the power cord on your dryer, make sure you get one that is designed for a dryer application and is 10/3 type. ( 10 Gauge wire with 3 conductors)...
Unplug the original 4 prong plug from the receptacle and pull the dryer away from the wall to gain access to the back of it.
Next, loosen the cord clamp that allows the cord to pass thru the back panel and into the druer compartment.
Open the access cover to where the end of that cord is terminated on a terminal block of the dryer.
Note which color is attached to which terminal ( red to red,black to black, white to white and green to green)...
3 Prong cables do not use a ground wire ( green) in the cord so you would wire the red to red, black to black and white to white ( The red and black are the power conductors and the white ..which is normally terminated between them.. is in the middle. You can get a seperate insulated conductor wire and route it from the ground stud of the dryer to the receptacle metal casing but do this with power disabled at the circuit breaker box...
Hope this helps.
Regards,
Rick
Nov 29, 2008 | Whirlpool LER5636P Electric Dryer
Neptune power cord
hi. thanks for the question. the red to red black to black white to white green to the frame of dryer to ground. thanks the appliance doc please rate this answer
Oct 01, 2008 | Maytag Neptune MDE7500AY Electric Dryer
Need to change the cord on my Maytag MDE6000AYW from 3 prong to 4 prong. The (4) prong cable has black, white, green, red cables. Which colored cable connects to which terminal inside the dryer?
BLACK and RED are 110-120VAC each. WHITE is NEUTRAL - does not carry power. GREEN is GROUND. The Black, Red, and White Wires should connect to the terminal block & should correspond the colored wires already connected to the block from the machine. The Green wire should be grounded to the equipment chassis. I hope this answers your question.
Jul 13, 2008 | Maytag Dryers
Kenmore Elite 45986 Front Load Washer Logo
153 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
