Question about Kenmore 53342 / 53344 Side by Side Refrigerator
106.53342300 ice maker not making ice. Sometimes
106.53342300 ice maker not making ice. Sometimes makes ice for a couple of days, then stops for a week or more. Water does not appear to enter mold. Saddle tap was replaced with separate shutoff and compression fitting. Worked for about a week and then stopped.
  • 986 Answers
I have a Frigidaire GSI 26, ffor the last couple of days it has been making a buzzing sound that lasts about thirty seconds to a minute, today the freezer quit working. the compressor is hot, as is th
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Ice maker not making ice.
TRY DISCONNECTING THE ICE MAKER FROM INSIDE AND RUN HOT WATER OVER IT UN TIL IT IS COMPLETELY THAWED, THEN RECONNECT IT AND SEE IF IT WILL MAKE ICE NOW. SOMETIMES ICE MAKERS CAN BECOMED BLOCKED BY ICE.
Apr 12, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Ice maker overfilling
OK i took a look at the ice maker. this has a shut off arm. i am guessing it always shut off automatically when you 1st had it right? but now it just makes too much ice. does it still do it if you lift the shut off arm up? if you lift it up and still makes to much ice then replace ice maker. (wait a couple of days)
if it stops making ice then just shut it off every other day thanks
Mar 28, 2010 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
My whirlpool ice maker makes ice just fine but it does not eject the ice you have to raise up on the arm then push it back down sometimes repeating this procedure a couple of times.it is the module type...
Good day,
Make sure the wire is inserted properly. If it is, then the module is failing. You can buy the module itself but there are many other parts to an ice maker and it is not considered to be long term cost effective. Most replace the ice maker complete.
To be sure. Remove the ice maker, unscrew the module and remove. Try resetting it 2 or three times, then re-install. If there is no improvement, replace the ice maker.
Mar 03, 2010 | Whirlpool ED2FHEXN Side by Side...
Six hours to make eight cubes???
when you first hook up an icemaker it sometimes takes a couple of days for it get up to speed. there may not be a problem give it some time.
Sep 30, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
GE Side by Side: Ice Maker Issue
Is the freezer working at the correct temp ?? Is the ice maker feed pipe blocked ??
Apr 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
NO ICE - IC6
George, the ice maker will cycle about every 2.5 hours. Sometimes it takes a couple cycles to prime the lines. You can remove the white cover of the ice maker. On the module you will see two ports, one marked L and another marked V on the left side. Take a insulated jumper wire and jump these two terminals. You are now sending 120V to the valve. See if the water starts coming in. Also make sure the bailing arm is down. Catriver...post back.
Nov 05, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kenmore 53342 / 53344 Side by Side Refrigerator Logo
231 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
