Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Blue or yellow marks in screen - Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Sony Vaio has blue screen of death
try starting in safe mode (pressing F8 on start up) check in device manager to see if you have any problems with drivers (any yellow exclamation marks)
Feb 25, 2013 | Sony Vaio Pcg-71312l Laptop Screen 15.6...
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Peavy 112 monitor,1 yellow and 1 blue wire going to speaker .Which is positive,and negative?Thanks:)
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; color: #1a1a18}
The wire which is coloured and yellow must be connected to the terminal which is marked by the letter E, or by the earth symbol.
The wire which is coloured blue must be connected to the terminal which is marked with the letter N, or coloured black.
The Yellow coloured wire is going to be the positive, and the Blue wire is going to be negative wire.
Jul 18, 2011 | Audio Players & Recorders
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Please send me cheats in guitar hero II
To unlock everything in the game, due the following code on your guitar at the title screen: Blue, Yellow, Orange, Red, Orange, Yellow, Red, Yellow, Red, Yellow, Red, Yellow.
Performance Mode ... YELLOW, YELLOW, BLUE, YELLOW, YELLOW, ORANGE, YELLOW, YELLOW
Hyper Speed ... ORANGE, BLUE, ORANGE, YELLOW, ORANGE, BLUE, ORANGE, YELLOW
Air Guitar ... YELLOW, YELLOW, BLUE, ORANGE, YELLOW, BLUE
Eyeball Heads ... BLUE, ORANGE, YELLOW, ORANGE, YELLOW, ORANGE, BLUE
Moneky Heads ... ORANGE, BLUE, YELLOW, YELLOW, ORANGE, BLUE, YELLOW, YELLOW
Flaming head ... ORANGE, YELLOW, ORANGE, ORANGE, YELLOW, ORANGE, YELLOW, YELLOW
Horse head ... BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE
Air guitar ... BLUE, YELLOW, ORANGE, BLUE, YELLOW, YELLOW
Eyeball Heads ... YELLOW, ORANGE, BLUE, ORANGE, BLUE, ORANGE, YELLOW
Hyper Speed ... YELLOW, ORANGE, BLUE, ORANGE, YELLOW, ORANGE, BLUE, ORANGE
Monkey Heads ... YELLOW, YELLOW, BLUE, ORANGE, YELLOW, YELLOW, BLUE, ORANGE
Flaming Head ... YELLOW, YELLOW, ORANGE, YELLOW, ORANGE, ORANGE, YELLOW, ORANGE
No HUD performance mode ... YELLOW, YELLOW, ORANGE, YELLOW, YELLOW, BLUE, YELLOW, YELLOW
Horse Head ... BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE
Jan 06, 2009 | RedOctane Guitar Hero 2 Game For...
1988 mark 7 color code for sound system
1986-89 Lincoln Mark VII Stereo Wiring Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red Illumination Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) Pink/Blue Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Green Left Rear (-) Blue/Orange Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
Aug 17, 2008 | 1988 Lincoln Mark VII
Yellow brush marking on Screen
Your problem is with the blue color,maybe some dirt is sitting on the face of the blue crt and is being projected bigger to the screen,you should try cleaning the face of all 3 tubes,if you familiar with tv service this should help,be careful when removing the back and make sure the set is unplug when you do the cleaning.Let us know how it goes.
Oct 06, 2006 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
