Question about GE Refrigerators
I can not get the temperature in my refrigerator below 50 degrees. The freezer is fine.
  • 54 Answers
Try an adjust the knob on the interior and if u tried that attempt to clean out behing and underneat the fridge to get better venalation. Also it may be ur pump it orobley low on freeon. also check the seal if not u may need a new or used but good fridge.
Posted on Oct 06, 2009
Testimonial: "Gave some good basic tips, which I did t5o make sure. However, if I told you that freezer was fine, why would you suggest checking the freon? Thanks"
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
Can any make of freezer be used in garage. Told only Beco
Refrigerators are designed to be used inside at typical to normal household temperatures. The problem with refrigerators are if the ambient temperatures drop down below 55 Degrees F Food in freezer will begin to defrost when the temperature in the garage goes below 55 degrees Fahrenheit. The fresh food section may begin to freeze food slightly below this temperature. If you live in an area where the outside ambient temperature does not get below 70 degrees F or 20 degrees C then the refrigerator will work fine but to have it located in an area where temperatures drop well below this you could lose some food. There are heaters that can be adapted to the compressor if used in an unheated area. Hope this helps, Sea Breeze
Jul 05, 2012 | Whirlpool Freezers No Refrigerator Model...
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
What is the proper temperature for a refrigerator be and what is the proper temperature for the freezer?
A refrigerator should maintain temperatures at or below 40 degrees F. The freezer temperature should be 0 degrees F or lower
May 13, 2011 | Amana Refrigerators
Freezer section working, but refrigerator section will not drop the temperature below 50 degrees.
You have a defrost problem. Remove the cover in the freezer and see if coil is blocked with ice.
If it is defrost it with a hair drier, check heater, timer, defrost thermostat.
Feb 25, 2011 | Summit Commercial FF-882W Top Freezer...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Freezer will not work due to out side teperature being low
Sorry, not doable. Temp in garage below 50 degrees will cause problems with any domestic fridge or freezer. The soda machines you see outside actually have heaters in them so they can work in the winter. Hope this helps!
Jan 06, 2009 | Hoover HCA351K Bottom Freezer Refrigerator
FREEZER TOO COLD - REFRIGERATOR TOO WARM
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 30, 2008 | KitchenAid KSRG25FK Side by Side...
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
