Question about Gateway MX3215 Notebook
Screen Helllo, My 14-inch Widescreen Ultrabright WXGA TFT (Gateway MX3215) works when started then dies. Restart will make it come back but disappears. Can use video port to connect into monitor and works fine. Is this an inverter issue with the display? Is it worth fixing. Thanks
  • SJB2007 Dec 26, 2007
    Tom,
    You deserve a high rating for clarity, response time and (which i also believe) accuracy. I still need to find one and replace it. thanks for confirming my suspicions.
    SJB
    Genius:
  • 1,601 Answers
Yes, and yes.
If it is still under warranty have Gateway fix it.
If not
Go on Ebay and you may find the part cheap.
Posted on Dec 23, 2007
  • Thomas Christopher
    Thomas Christopher Dec 26, 2007
    Your welcome and thanks for the update!!
What is the difference between mx3231 mx3228?
The screens are probably interchangeable. The two laptops have the same size screens, 14-inch Widescreen Ultrabright WXGA TFT. The major difference between them is that the MX3231 has a CD writer/DVD-ROM optical drive. The MX3228 has a dual-layer DVD writer. See https://support.gateway.com/s/Mobile/Q106/MagicLC/1009130sp2.shtml and http://support.gateway.com/s/Mobile/Q106/MagicLC/1008831sp2.shtml for the specs of both of these Gateway notebooks.
I hope this helps.
Jun 03, 2012 | Computers & Internet
Gateway mx3222b laptop ram upgrade problem
your computer does not support 1GB memory sticks. The max memory for that system is 1GB which would be 2 sticks configured as 512MB
see below for the specs (i bold, italics and underlined the main part)
Processor Intel® Celeron® M Processor 370
1 MB L2 Cache | 1.50 GHz | 400 MHz FSB Display Screen 14-inch Widescreen Ultrabright™ WXGA TFT Chipset Via VN800 Memory 256 MB DDR2 (1 × 256 MB) SODIMM
Total slots: 1 DDR2 slot | Available slots: 0 DDR2 slots
Expandable to 1 GB Video S3 Graphics UniChrome™ Pro IGP
Up to 64 MB shared VRAM Audio AC'97 2.3 Compliant Hard drive 40-GB 4200 RPM hard drive Optical drive DVD +/- RW Multi-Format Double Layer
Write maximum: 8X DVD+/-R, 6X DVD-RW, 8X DVD+RW, 2X DVD-R DL, 2.4X DVD+R DL, 24X CD-R and 16X CD-RW discs
Read maximum: 24X CD-R/RW/ROM, 8X DVD-R/RW/ROM, 4X DVD+/-R DL, RAM discs Media Reader 4-in-1 Digital Media Manager
Secure Digital™, Memory Stick®, Memory Stick-Pro®, and MMC™ Modem 56K ITU V.92 ready fax/modem Network 10/100 Mbps built-in Ethernet
802.11g integrated wireless (up to 54 Mbps) Interfaces
  • 2 - USB 2.0 ports
  • 1 - VGA external connector
  • 1 - RJ11 (modem)
  • 1 - RJ45 (Ethernet LAN)
  • Microphone jack
  • Headphone jAck
Pointing device Touchpad with vertical scroll zone PCMCIA 1 - Type I or Type II; Card Bus Battery 6-cell Lithium-ion Dimensions 1.1 to 1.24-inches (H) × 13-inches (W) × 9.7-inches (D)
28 to 32 mm (H) × 330 mm (W) × 246 mm (D) Weight 5.01 pounds
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
Chipset Via VN800
Expandable to 1 GB
Interfaces •2 - USB 2.0 ports
•1 - VGA external connector
•1 - RJ11 (modem)
•1 - RJ45 (Ethernet LAN)
•Microphone jack
•Headphone jAck
Weight 5.01 pounds
Mar 03, 2010 | Gateway Computers & Internet
I've turned my speakers down and i can't hear any
try to go back into your sound settings and see if the mute all button in te first colum selected if so unchech and then try to play a song to see if it helps
Dec 02, 2009 | Gateway P-6301 Notebook/ 17-inch...
Gateway p-6301 drivers for windows xp
Below will take you to gateway's support website. This page lists the only drivers for this laptop provided for windows XP.
P6301 drivers
Hope this helps.
Thanks,
Lolita
Sep 25, 2009 | Gateway P-6301 Notebook/ 17-inch...
Can i replace my Gateway laptop tft screen with a new lcd screen?
The screen resolution is a combo of:
  1. the screen's capability
  2. the video card's capability
  3. the driver's settings
If the above screen is made for this laptop (as it appears to be), then the settings you had should still be there.
Jul 29, 2009 | Toshiba LCD TFT Monitor
Could I upgrade my Gateway MT3707 160G hard drive?
You can upgrade your hdd as big as they make in 2.5 inch format. Just make sure you get a drive with the same format as your old drive or it will not work. Hope this helps.
Jun 16, 2009 | Computers & Internet
In Youtube, when I click full screen, the screen turns blank.
you just right click and select a particular file for ex media player
so that u will able to view it
Mar 21, 2009 | Gateway MT6729 Notebook
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Motherboard Replacement
I would check Ebay you may be able to find a replacement one for cheap.
Jan 07, 2009 | Gateway MX3560 Notebook
GATEWAY 7330GZ PC NOTEBOOK
This link will provide you the required information.
Specifications
Part Number: 4997Gateway 7330GZ Notebook
System Gateway® 7330GZ Notebook Processor Mobile Intel® Pentium® 4 Processor 532 with HT Technology
(1MB L2 Cache | 3.06GHz | 533MHz FSB) Determine Your Processor Speed
Chipset Intel® 852GME Screen 15.4-inch Widescreen Ultrabright TFT WXGA
  • Maximum Resolution: 1280 × 800
  • Maximum Color Depth: 32-bit (16.7 million colors)
  • LCD maximum refresh rate: 60 Hz
Memory 512 MB DDR (1 × 512 MB), 333 MHz, DDR
Expandable to 1.5 GB Video Intel® Extreme 2 Graphics
Dynamic Video Memory Technology (DVMT) supports up to 64 MB shared video memory Audio PC2001 Compliant AC '97 Audio
Built-in Stereo Speakers Hard drive 80 GB HDD (4200 RPM) Optical drive DVD +/- RW Multi-Format
  • Write maximum: 8X DVD +/-R, 4x DVD +/- RW, 24x DVD+R DL, 24X CD-R and 10X CD-RW disks
  • Reads maximum: 8X DVD-ROM Disks, 8X DL/+RW, 24X CD-ROM disks
Media reader 6-in-1 Digital Media Manager
Compact Flash, Micro Drive, MultimediaCard (MMC), Secure Digital (SD), Memory Stick, and Memory Stick Pro Modem 56K ITU V.92 ready Fax/Modem Network 802.11g integrated wireless (up to 54Mbps)
10/100Mbps integrated Ethernet LAN Pointing device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces
  • 4 - USB 2.0 Ports
  • 1 - VGA External Connector
  • 1 - IEEE 1394 port
  • 1 - RJ11
  • 1 - RJ45
  • Microphone In
  • Headphone/Audio Out
Battery 8-cell Lithium-ion Dimensions 1.6-inches H × 14.0-inches W × 10.4-inches D Weight 7.5 pounds (8.65 pounds total travel weight)
Mar 24, 2008 | Gateway 7330GZ Notebook
Gateway MX3215 Notebook Logo
70 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
